Question about Canon ZR400 Mini DV Digital Camcorder
My Canon ZR400 Digital Camcorder would not charge battery and will not turn on. It just stop working, i cnanged the battery pack and it did not work. Even a fully charged battery could not help.
    New Friend:
  • 95 Answers
It needs to go to Canon for service.There is a internal component failure
Posted on Mar 26, 2010
SOURCE:
Camer will not power on
If your battery does not seem to charge, then you need to carry out some tests on the device, the battery and the charger. First you insert the battery into another cam corder then you try to charge, if it charges, then it means the battery is okay and if it does not charge, then it means the battery is bad and need to be replaced.
Then i will advice you take the charger and try to charge another device to see if it will work, if it works, then it means the charger is alright but if it does not then it means the charger is bad and need to be replaced.
Finally, test the camcorder by plugging a well tested charger and battery into it and trying to charge it, if it does not charge then the problem is from the camcorder.
Feb 12, 2014 | Canon MVX20I Mini DV Digital Camcorder
My canon don't power on with a battery but power on with a charge can you help my to now what is the bad fuse? thank
try a new battery pack or let your's charge for 12 hres
about ;its seems that the battery pack you have is low in charge;because if its works with the chargerit should works with battery;about the bad fuse if it was the problem ,the camera will not work at all,
and that is a big problem that fuse is inside the camera on the pwr board,
hope that will help.
May 07, 2010 | Canon FS200 Flash Media Camcorder
Grey line on the screen when playing de video
The head unit that reads the tape is dirty or clogged, or the tape has moisture on it. Try fast forwarding to the end of the tape then rewinding back to the beginning, sometimes this clears the moisture. If that doesn't work try buying a head cleaner from an electronics store and follow the instructions to clean the head. if that doesn't work you need to take it somewhere where they fix cameras or send it in to canon to get fixed. If nothing else works it's most likely a bad head. I have the exact same cam (zr400) and the same thing happened to me but rather than send it in to canon, (who refused to honor their warranty saying it had major sand damage when it never even went outside) i opened it myself and replaced the head with the one from my older zr65 camcorder. It worked flawlessly. Hope this helps -J
Dec 19, 2009 | Canon ZR400 Mini DV Digital Camcorder
Battery pack use
I have a similar problem. My MV650i works from the mains power but not from the battery even though I have tried new battery packs.
Feb 01, 2009 | Canon MV650i Mini DV Digital Camcorder
Battery pack for Canon ZR100 digital videocassette camcorder
For good spare canon nb-2lh battery,or cheap replacement canon nb-2lh digital camera battery,you can search and searh to find a famed relible camera camcorder batteries store with chargers on sale,shopping online convenient and cheap !
Jun 25, 2008 | Canon ZR100 Mini DV Digital Camcorder
Battery pack use
Have you charged your battery?
Your battery may need to be replaced. Radio Shack carries them for about $20 - $30 a piece depending on how long the life is in them.
I carry a few for my camcorder just for that reason. Then you will have a backup source.
Jun 15, 2008 | Canon ZR80 Mini DV Digital Camcorder
My canon zr400 wont turn on
ITs most likely a fuse, unfortunately you can change it or its a son of a gun to change. You can check by removing the motherboard, locate the fuse, they are micro fuses, it either has the letter H or K etched on it, there could be anywhere from 1-5 of those fuses. Check for continuity if that s the problem than replace it, if you cant find a replacement micro fuse than solder over the fuse for continuity...that should make the camcorder power on, but beware once you solder over the fuse- there will be no more current protection for the camcorder. If the fuse is not the problem than it could be a loose circuit...
Feb 22, 2008 | Canon ZR400 Mini DV Digital Camcorder
Canon ZR40 would not turn on
The battery is probably so dead it is using all the power from the wall supply.  Remove the battery, and run only from the wall supply.
Dec 16, 2007 | Canon ZR400 Mini DV Digital Camcorder
Transfering video to Mac
Digital video on the ZR400 is transferred to a computer only via the DV out port, which will connect to a firewire port on a PC or a Mac. USB will not transfer video, only images to and from the card.
Nov 13, 2007 | Canon ZR400 Mini DV Digital Camcorder
Canon ZR400 Mini DV Digital Camcorder Logo
147 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
