Proform 740CS treadmill runs okay but the incline feature stopped working. I pulled off the cover and can measure voltages, but don't know what to check. Any ideas?
ProForm Treadmills have a reset procedure for the incline function. With the key inserted in the console, activate the incline; while the incline is changing, remove the key. Wait 30 seconds, then replace the key. The incline should to maximum, then to minimum, resetting its limits. It worked for mine just 10 minutes ago; the procedure is in the manual if you have it. Good luck!
The incline does not move nor hear the motor trying
Can you hear the motor trying to work at all? If it moves a little, but not to capacity it may just need calibrated.
incline works
