Grundfos MQ3-35  3/4 HP Pressure Booster Pump  Logo
Posted on Mar 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
With the water running the MQ pump runs intermittently
With the water running the Grundfos MQ pump runs intermittently. The pump cycles on and off when a faucet is on.
Anonymous
Level 3:
  • Master 990 Answers
  • Posted on Mar 09, 2010
Anonymous
Master
Level 3:
Answers
990
Questions
Helped
468726
Points
2217
This is a problem with your bladder in the pressure tank or the pressure switch. Ether one will produce this cycling on and off. Good luck.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 04, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2565
Points
How to fix the water pump?
Grundfos pump
Louise, since there is several different types and models of Grundfos pumps it would be hard to answer your question. To possible point you in the right direction below are a few links to where you can find some PDF documentation about a popular Grundfos pump the MQ series and direct link to the manufactures "Service Support".
Service support
Grundfos MQ Series Pumps
Feb 07, 2014 • Garden
Grundfos MQ 35 won't run
Sounds like the discharge is plugged. You can get the manual at: http://rainwatercollection.com/download/Grundfos-Manual.pdf
Jan 24, 2014 • Plumbing
1helpful
Grundfos runs intermittently and needs power cycle to get going again
What type of pressure switch or pump controller on pump? Could be capacitor check. with power on try spinning fan at rear if starts probably cap. Have it checked. Could be controller faulty.
2helpful
4answers
Grundfos MQ pump starts every 15 seconds
Pressure is bleeding back through the pump or system to the tank or well or where ever the water is coming from. Should be some sort of one way valve to keep water from going back to the source, mounted somewhere so that once pressure is pumped up, it will hold that pressure in the part of the system that has the pressure switch that controls the pump.
That or you have a leak where you can't see it. (Actually you do, it is just internal and not leaking outside the pipes!)
Hi I have a Grundfos pump which both my showers run off. It has been working fine for a year but is now intermittent...it is ok for the first shower of the morning and then cuts out...it works very...
Hi Hayley.
Please allow me to try to help you.
Random water pumping or intermittent water pumping, appears to be quite a commonality with the Grundfos pump. The solution to this is quite a bit of process, the details of which you can get here...
http://inspectapedia.com/water/Intermittent-Water-Pump-Cycling.php
I have also attached a video, trust that gives you a bit more insight.
Hope that helps.
Best wishes. Regards.
I have a problem with the MQ-35 pump starting and running for about 10 minutes when there is constant demand (such as running a sprinkler) and it then alarms and shuts off for 30 minutes before it will run...
This sounds like a issue with air still being in the system and not being removed from the system to make things work properly. I did try to findthere number and was unable to locate it. The only other option for you is to return the product and find one with better support
1helpful
2answers
My Grundfos MQ pump intermittantly continues to run when there is no demand, especially after drawing off a small quantity of water. It then overheats. The plumber has replaced the pressure tank but the...
I have the same problem and have found that the inlet check valve has a broken shaft in the center of device. It is a multi-piece plastic unit and it looks as if it is not quite seating and therefore the internal pressure leaks slowly back into my low pressure suction line. The pump will start and the pressure will build then shut off for about 30 minutes then cycle again. I am going to replace the check valve.
Top Grundfos Garden Experts
john h
Jay Finke
Jay Finke
ADMIN Eric
ADMIN Eric
Are you a Grundfos Garden Expert? Answer questions, earn points and help others
