I have an old Troy Bilt with model #HH60-105106F (I think this is what is says). What is the horse power on it and how do I find a wheel shaft assembly?
Re: Old Troy Built with model #HH60-105106F. What is
That's the engine number. It's a 6Hp Tecumseh. Go on ebay and buy the Troy Bilt parts manuals on CD for Horse Roto Tillers (if that's what it's on). I paid $8. Definitely worth it.
without a proper model number it is guess work, but either the drive belt has snapped, or if the right wheel drive the left wheel, there may be a half moon key way or a shear pin. General help here, followed by parts suppliers
it is how much power the motor has. In the old days people travelled on horses . One horse produced one horse power. So if you had a buggy with 5 horses attached to it you had a five horse power buggy. So your schredder engine has the equivalent power produced by five horses.
https://en.wikipedia.org/wiki/Horsepower
The wheel shaft on a Horse tiller is one piece so if the shaft turns on one side it will turn on the other. make sure the pin that holds the wheel on is not missing that would let it spin on the shaft. That's the only thing I can think of that would cause that problem. Hope that helps.
Go to this website and type in Horse for your model number.Just put thenumber 1 in for your serial number and it will bring up several horse tiller manuals. If yours is a 1976 then it should be
a Horse I model. This should be a two speed tiller and have two drive belts.
The older models do not have an actual model number but only a name to distinguish the size. Early production models include the Horse, Pony and Junior. You must find the location of the serial number tag to order parts that will fit your particular rototiller for seamless replacement of parts. Hope this will help
if you have a B&S engine look at the frist two numbers on the code. thats the year of the engine and more likelyof your unit, As long as the motor has'nt been replaced. I'll checked on your serial number did'nt find a model. If this is an old troy built I'll have to call tech support. also I need to know what engine 4, 4.5, 6, 7, 8, hr power, and the name of the teller. MTD now owens troy built.
The serial number is stamped on the upper right hand side of the gear housing. It is on a flat spot just above the wheel shaft. If it is a newer model it will be on a white sticker on top of the gear housing plate. If it has the T handle it is probably an older 1980's model. If you find the six digit number I can give you the year it was made.
