Washers can leak due to a problem with the water inlet valve that isn't connected properly or just faulty, unfortunately these cannot be repaired and need to be replaced. There are times when the door seal is ripped or cracked and that would be the reason for the leaking washer.
Check the drain pump: The drain pump pumps out water from the drain hose. If the drain pump is cracked, has leaking seals or the bearings are worn out it can probably be repaired. In some cases a new unit may be the best and/or cheapest solution.
Check the tube seal: This is a major problem. If the tube seal is leaking it may get water on other washer parts that should not get wet, such as the bearings. This is a complicated repair as most of the washer will have to be disassembled to access the tube seal.
If the oil plug bolt is leaking you need a new aluminum sealing washer. There are no oil weep holes in the front of the motor. Is it the weep hole under the water pump? You probably have a bad water pump seal or a bad oil seal on the water pump shaft. Buy a new water pump and the K&L water pump gasket kit. The K&L gasket kit comes with all the gaskets, seals, and washers necessary to do the water pump replacement for a fraction of the cost of the OEM Honda individual gaskets, seals, and washers.
sounds like the seals and o'rings are worn and causing the pump to leak water.also one of the pistons might have a crack in them.dis assemble the pump and inspect the pistons,if none are cracked,then replace all the o'rings and seals.this should stop the pump from leaking.
The fill hoses : These are located behind the washer and are connected to the water mixing valve and faucets. Pin holes and cracks on the hoses may cause them to leak.
The water valve: The water mixing valve is located behind the washer. The fill hoses connect to the water mixing valve. Inside of the valve is that the water gets directed to the filling spout. Water leaks happens when the valve develop pin holes or cracks. Bad fill hoses or water valve could be the reason why the washer is leaking water.
The Filling spout: Is just a directing part, this part directs the water from the water valve to the tank. Pin holes and cracks is what make this part to leak.
The tank : The major cause for the tank to leak is through holes or cracks that the tank develops because of vibration or metal items hitting the tank during the spin cycle.
The tub seal : The tub seal is made of rubber, it is connected between the transmission post and the center of the tank. Leaks developed when the seal gets worn out and it looses the ability to make a good seal between the transmission and the tank. A crack tank or worn out tub seal could be the reason why the washer is leaking water.
The overflow tube : This tube is use to direct the water away from any electrical parts like the motor in case of an overflow cause by a bad water mixing valve or bad water level switch.
The pump : The pump job is to remove the water from the tank to the drain pipe. This pump has an electric motor and an impeller. When the pump motor is turning, any water that falls in to the impeller, is push out to the drain pipe.
Most leaks are cause by a worn out seal between the front pump housing and the rear one.
The drain hose : The drain hose is made of hard plastic and some times it develops pin holes and cracks leaks. Bad pump or drain hose could be the reason why the washer is leaking water.
Thanks for using FixYa and do rate the solution as Fixya if found helpful.
The Krups heats the water through a horseshoe shaped aluminum tube which the heating element is wrapped around the tube in the same fashion, the tube is corroded or cracked most likely, if you poured cold water into the machine when it was hot, this will crack the tube, they are made by Cesod ? which is stamped on the element with a number on it, and I have seen between 700 and 1100 watt elements. I have the same problem with my 7 year old krups coffee maker, Im trying to repair the tube with aluminum welding or find a new element. It could also be the high temp tubing may be cracked. You need tamper proof Torx bits to remove the bottom cover on some models.
