Question about Hotpoint Ultima WF860 Front Load Washer
Error code on washing machine wf640
I came home from work and my kitchen had flooded when i pulled the washer out one of the pipes had fallen of put new pipe on and when i put the washer on it is flashing f-01
  • 58 Answers
Have you checked you have turned on the water back on???? check but red and blue, or just blue it must be 90degree left or right.
Posted on Mar 09, 2010
SOURCE:
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
F11 error code on whirlpool HE3
Water up to door level means your motor and motor control unit (MCU) was covered with water. Most likely your Motor control unit (MCU) is damaged rather than Central Control Unit (CCU).
Listen, you have to buy a new machine. If you end up putting CCU and MCU both into a soaked wash motor washing machine, you will be so mad with yourself.
Time to go to Home Depot looking for a new machine.
You use that flooded machine then all your washing machine warranty and liabilities from the manufacturer is out of the door. Even your home insurance may not honor if you knowningly use a flooded machine and something goes wrong.
Oct 09, 2017 | Whirlpool Duet GHW9150P Front Load Washer
H20 ERROR SPIN DRYING
The error indicates a problem with the incoming water supply.
Check for restricted or kinked inlet hose/s, check that tap/s are fully turned on and that you have adequate water pressure.
Mar 27, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
The twin tub connected to the washing machine doesn't drain.
The laundry tub does not have adequate drain size to handle discharge from the washing machine. In addition, the kitchen and laundry area piping may not be correctly vented.
May 17, 2017 | Daewoo DW500M Top Load Washer
Machine overfilling
You need to check the pressure switch and tube wich you can access from the top of the machine with the top removed. the tube is a rubber pipe which may have fallen of the switch or pressure chamber connection. cheers
Mar 25, 2009 | LG WM1812C Front Load Washer
Ashing machine not emptying
check the drain pipe is not blocked, to empty the machine manualy get a bowl on the floor and lower the drain pipe into it and fill to stop water flow lift pipe up in air and lower to start draining again when empty if pipe not blocked i would suggest a new pump located under the drum and easy to fit
Feb 05, 2009 | Hotpoint WMA46 Front Load Washer
Hoover AAA 160 Washer error code 4
PLEASE INSPECT DOOR BOOT (RUBBER DOOR GASKET) IF NOT CAN BE FILL VALVES NOT COMPLETELY TURNING ITSELF OFF ,,, IF ALL LOOKS GOOD REPL/ PRESSURE SWITCH
Nov 29, 2008 | Hoover AAA160 Front Load Washer
Error code h20
hi sounds like a faulty fill valve easy fix
Sep 17, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WF640
the f-01 error code on your hotpoint all in 1 washer/dryer is a short circuit code for the motor. the only way to clear the code is to have a service tech come and inspect the reason for the error.
May 12, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing machine heating element
remove the front panel of the machine, remove the element and slacked off the centre bolt, apply a layer of clear silicon to the rubber seal refit tighten centre bolt leave overnight and test the following day, this will resolve the problem.
Sep 07, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
89 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
