My desk top turns on, and shows a blue screen with HP in the center and
v 3.13
It reads esc- Boot menu , F1- set up, F10-System Recovery .
I tried Esc and F1 But my keyboard doesn't respond. What do I do?
Shut your computer down and remove the power cord.
Replace the power cord and press the "Power" button to restart it.
Watch the screen carefully for a message about computer setup.
Most computers use one of the function keys, which are aligned across the top of the keyboard, to access the computer's setup utility, but each manufacturer uses a different key.
For instance, HP computers generally use the F1 or F10 keys, while many Dell computers use the F12 key.
Press the appropriate function key to enter the computer's setup program, then scroll through the list of options until you see "Boot Order."
The exact location of the boot order option varies from manufacturer to manufacturer, but it is often located under the Advanced menu.
Highlight the "USB Devices" option and press the up arrow key until that device is first on the boot order list.
This will force the computer to look at the external DVD drive first when it boots up.
Use the "Esc" key to exit the setup menu. Choose the "Save settings and exit" option and allow the computer to reboot.
It will now boot from the external DVD drive.
Hope this helps
ALR PC non / PCI = CTRL+ALT+ESC
AMD advanced micro devices=BIOS = DEL
Award BIOS = DEL
Dtk Datatech Enterprises Co. BIOS = ESC
Phoenix BIOS = CTRL+ALT+S
Phoenix BIOS = CTRL+ALT+INS
Restart your computer
during the boot process you will see on the screen to press a certain key usually Delete or F2 to enter setup
this will differ depending on which bios you have
Press and hold that key during the boot up process to enter BIOS
if you have changed any of the BIOS settings by mistake
you can load failsafe or optimised defaults using the arrow keys you can after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart
CMOS is an on-board semiconductor chip powered by a CMOS battery inside computers that stores information such as the system time and date and the system hardware settings for your computer..
If your computer won't boot without a password or you need a password to enter the computer set-up or change the settings, then you have a BIOS password set. BIOS is an acronym for basic input/output system.
The BIOS is the basic instruction set that teaches the computer how to access disk drives, keyboard, display etc. The BIOS is typically placed on a ROM chip in the computer hence the term ROM BIOS.
The ROM BIOS allows the computer to boot itself. The BIOS is required to boot the computer. Thus, if the BIOS is password protected, the computer will not boot (or you will not be able to enter or change the BIOS settings.)
using the arrows keys scroll to Advanced Bios Features change the first boot device to cd rom press escape the F10 save to cmos to restart
BIOS is a software program that controls basic functions in your computer, such as boot order, keyboard control and how your processor interacts with memory cards
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys scroll down to advanced bios features press enter to change boot devices
press f10 to save to cmos escape then restart your computer
if you need to change any of the settings using the arrow keys if you have made any changes that has compromised your computer
you can go back and load failsafe or optimised defaults
hope this helps you
I have toshiba laptop and when I try and turn on computer the power supply is Ok but I get a blank screen and when I try cap locks that light does not light up. Do you think I have a problem with the mother board or is there something else wrong with the computer. I just get a blank screen and also my softwear drive does not seem to operate.
HELP
i have a compaq, an the compaq screen pops up as i turn it on, the fan's kick in for a bit but the keyboard is not getting power it seems, no lights come on, then after a while SOMETIMES it goes to an all black screen with a little white underscore flashing at the top left, then one light comes on but no other lights come on if i press it, an no buttons work, it was working fine just before, all i did was just turn it off for the night
