Televison & Video Logo
Anonymous Posted on Mar 08, 2010
Need rca crk17sa users guide for codes for Magnavox TV
Anonymous
Level 1:
New Friend:
  • Contributor 27 Answers
  • Posted on Mar 08, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
27
Questions
0
Helped
7936
Points
67
Ok it took me a while. Go to this link to find the codes for you remote: 10054 is the most used code for Magnavox. I hope this helps you out. Good Luck!!!!!!!
http://www.directv.com/DTVAPP/content/remote_codes
Here's how to program your DIRECTV remote control:
  1. Press MENU on remote.
  2. Select "Parental, Favs and Setup"
  3. Select "System Setup"
  4. Select "Remote"
  5. Select "Program Remote"
While aiming remote at device, follow onscreen instructions to program remote to TV, DVD, or other device.
How to program the white DIRECTV remote to your TV
  1. Look up the control codes for your DIRECTV remote control.
  2. Make sure your TV is turned on.
  3. Slide the mode switch at top of remote to "TV".
  4. Press and hold the MUTE button. This is located above the number 1 button.
  5. While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice.
  6. Enter the first TV code you have. The green light on remote should flash twice.
  7. Aim remote at TV and press PWR button once. The TV should power off.
  8. Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
If the TV does not power off, repeat steps 4, 5, 6 and 7, using the next code for your TV brand.
If remote control fails to program using all available codes, try scanning for the code.
How to scan for TV codes on your DIRECTV remote
  1. Make sure your TV is turned on.
  2. Slide the mode switch at top of remote to "TV".
  3. Press and hold the MUTE button. This is located above the number 1 button.
  4. While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
  5. Then enter 991, the green light on remote should flash twice.
  6. Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
  7. When the TV powers off, press and release the SELECT button.
Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
2answers
How do I program it to a Magnavox tv flatscreen
Programming an RCA Universal Remote - YouTube
? 2:46
https://www.youtube.com/watch?v=MZd4yBivcZ4
Nov 10, 2008 - Uploaded by alpharedecho
... how to program an RCA Universal remote for operation with your TV. ... Still in able to work or my rca flat screen and my zenith. .. ive .... I'd do it over and over and the power button on the remote just turns off in the end?.
Magnavox TV codes - Magnavox TV set. Buy, reviews ...
magnavoxtv.org/magnavox-tv-manual/magnavox-tv-codes/
Helpful Resources for Magnavox TV codes. Press and hold ... Note: If some buttonsdo not operate your equipment, try one of the other codes for your brand. TV.
RCA Universal Remote Control- Target Programming ...
Unable to turn magnavox TV on. Child lockout is on and unable to turn on TV. Do not have original Magnavox remote. I do have a Universal RCA Remote. Can you give me the code for my RCA Universal...
What brand is your universal remote? Best thing would be to go on the universal remote manufactures website and they should have a list of codes for models based on what model number your universal remote is. Then you can look up possible codes for your tv found in the users manual (which you can print from online) and it gives you like 5-7 codes that you try and will give you instructions on how to enter the code and save that code to your remote. I hope that helps.
1helpful
3answers
I have a RCA Universal RCU430-needcode for Magnavox TV
Code 000 for Magnavox TV Code 004 for Magnavox TV Code 006 for Magnavox TV Code 008 for Magnavox TV Code 019 for Magnavox TV Code 062 for Magnavox TV Code 068 for Magnavox TV Code 069 for Magnavox TV Code 075 for Magnavox TV Code 076 for Magnavox TV Code 077 for Magnavox TV Code 088 for Magnavox TV Code 130 for Magnavox TV Code 132 for Magnavox TV Code 133 for Magnavox TV Code 134 for Magnavox TV Code 183 for Magnavox TV Code 219 for Magnavox TV Code 235 for Magnavox TV
I HAVE ACRCU410 RCA REMOTE I NEED IT TO WORK ON A MGNAVOX/PHILLIP
Try 026 as the code......this link will take you to where you can download the user guide for your remote.
http://66.77.167.109/rcaaccessories/RcaaccessoriesInfo.do?findManual=rcu410
please take the time to rate this solution
1helpful
I have a rca remote (rcu404) my tv is a magnavox. I can not find my book so I need help finding the correct code to program the remote to the tv. Thanks I do not have the code book for my remote control....
2helpful
Programming a RCA Universal remote to a magnavox tv
Hi tinalynn1071
I couldn't find the book anywhere for you,but did find a guide on programming RCA universal remotes, and a list of standard codes you may wish to try:)
regards
robotek
2answers
How to Auto tune remote control for 1993 Magnavox
try these codes: 1454*,0054,0030,0706,1963,1944,1254,0747,1454,0802,0386,0230,0187,0186,0179,0096,0036,0028,0024,0020
with this remote, press tv, then setup waiting for lcd (if there is one to flash twice. enter code. try to shut off tv. then turn it on and then back on hoping you have the right code. I have a 1993 magnavox and i am going to go through the codes again. 1454 worked the best but not everything. Good luck.
ps-i do not have a universal but a one from urcssupport.com so i am going there next. The booklet has hundreds for tvs, vcr, dvds.
3answers
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
