E-Machines eMachines Desktop PC Logo
Posted on Mar 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Making beeping sound when i start up the computer
Anonymous
Level 2:
Sergeant:
  • Expert 177 Answers
  • Posted on Mar 08, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
177
Questions
0
Helped
105483
Points
633
A beep sound can be due to memory problem.
First use the following steps:
1 Turn off the system and disconnect power cables
2 Press and hold the power button for 30 seconds
3 Reconnect power cables and try to turn it on.
If you still get a continuous beep sound, the next step will be to re-seat memory modules (after turning off the system).
When I am starting my pc it is making a long beep sound and my keyboard is not working every time I press f1 it is making a beep sound
Also, you can search for a free (or trial) download of [b]PC_Bios_Codes[/b] or similar on your browser.
I used this applet for many years, basically just a small database list of Beep codes for various BOIS'es. (AMI, Award, etc).
These beeps are the computer's audio code of system status, including any system/hardware errors it finds.
Sort of like 'SOS' in morse code.
Spins but makes a beeping sound and wont register.
Well, It sounds like there is something lodged in your Hardware drive...The beeping is probably a warning signal to tell you that it is not properly booting up...You should go to a Computer Repairman...
When booting the computer, there's a beep coming from the pc. how to disable?
you should not disabkle the beeper it is there for reasons like to give you warning beeps when ram or something is bad..the speaker is inside of the pc..
R52 thinkpad not boooting. making beep sounds on start up.
Welcome to Fixya
Beeping sound is telling you there is something wrong with the hardware. Different beeps has different meaning. Please refer to this link for the standard beep codes of your computer.
Hope this helps.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
1helpful
2answers
My computer always beep. when i am printing my computer beeps very long so i turn it off. i thought it was the cpu overheating. i put some thermal paste and turn it on when the computer is in the desktop...
hi Robin.
if your computer is making a beeping sound when it starts. No, you're not crazy, your computer really is beeping, and the sound may be coming from inside your computer, not your speakers.
These beeps are called beep codes and are used by the BIOS (the software that runs your computer hardware) during the POST (an initial test to make sure your computer is OK to start) to report certain initial system errors. If you're hearing beep codes after you turn your computer on, it typically means that the motherboard has encountered some kind of problem before it was able to send any kind of error information to the monitor. The beeping, then, is a way to communicate a problem to you when the computer can't show a proper error on the screen.
Follow the steps below to determine what computer problem the beep code is representing. Once you know what's wrong, you can work to fix the issue.
How to Troubleshoot Beep Codes
Figuring out why your computer is making beeping sounds should only take 10 to 15 minutes. Solving that problem that you identify is another task entirely and could take a few minutes to hours, depending on what the problem ends up being.
  1. Power on the computer, or restart it if it's already on.
  2. Listen very carefully to the beep codes that sound when the computer begins to boot.
    Restart your computer if you need to hear the beeping again. You're probably not going to make whatever problem you have worse by restarting a few times.
  1. Write down, in whatever way makes sense to you, how the beeps sound.
    Important: Pay close attention to the number of beeps, if the beeps are long or short (or all the same length), and if the beeping repeats or not. There is a big difference between a "beep-beep-beep" beep code and a "beep-beep" beep code.
    I know this might all seem a little crazy but this is important information that will help determine what issue the beep codes are representing. If you get this wrong, you'll be trying to solve a problem your computer doesn't have and ignoring the real one.
  1. Next you'll need to figure out what company manufactured the BIOS chip that's on your computer motherboard. Unfortunately, the computer industry never agreed on a uniform way to communicate with beeps, so it's important to get this right.
    The easiest way to figure this is out is by installing one of these free system information tools, which should tell you if your BIOS is made by AMI, Award, Phoenix, or another company. If that doesn't work, you could open your computer and take a peek at the actual BIOS chip on your computer motherboard, which should have the company name printed on or next to it.
    Important: Your computer maker is not the same as the BIOS maker and your motherboard maker is not necessarily the same as the BIOS maker, so don't assume you already know the right answer to this question.
  2. Now that you know the BIOS manufacturer, choose the troubleshooting guide below based on that information:
    Using the beep code information specific to those BIOS makers in those articles, you'll be able to figure out exactly what's wrong that's causing the beeping, be it a RAM issue, a video card problem, or some other hardware problem.
  3. Try to turn off beep sound in the BIOS
More Help with Beep Codes
Some computers, even though they may have BIOS firmware made by a particular company, like AMI or Award, further customize their beep-to-problem language, making this process a little frustrating. If you think this might be the case, or just worried it could be, almost every computer maker publishes their beep code list in their user guides, which you can probably find online.
See How to Find Tech Support Information
4helpful
2answers
MY ACER INSPIRE LAPTOP MAKE BEEPING SOUND WHILE BOOTING.
when i power on my laptop the acer logo screen is displayed on screen then the computer start beeping and the laptop get struck.i replaced the ram but the same problem arise.I removed the ram but the laptop wont startup and no beeping sound.When beeping start the laptop cooling fan get stopped.
1helpful
Computer dead and beeping
If it beeps and not boot then it is the post routine telling you there is a problem. The post routine is run when you turn the power on to ensure the computer hardware is ok to run. The manufacturer of the bios routine can tell what is wrong by the type, number and duration of the beeps. Look up the code meanings and it will indicate the problem. If this sounds like nonsense to you then give the make and model of your machine and what the beeps sound like. ( beep beep beep delay beep beep beep) etc. and I'll look it up for you.
Can't start up computer
The siren sound is a alert sound that your processor is overheated. please check the processor heat sync and fan installed properly?
Doesnt switch on
You said buzzing sound is this more like a beep? Beeping sound are indicative of any number of diagnosable issues, depending on the actual number of beeps and the type of motherboard.
2answers
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
