Hi.. I have my Netdisk working perfect very well installed in my older laptop with Windows XP ,but now I have a New Sony Vaio With Windows Vista, and I installed the cd, but doesn't work appropiated in my new computer.. I think that I need an upgrade for Windows Vista... Can anybody help me please? thanks.. Nena A
You need to stop using Vista as Microsoft has not supported it since 2014. OK to use Vista for a while after 2014 because Windows Update still gave security updates for other Windows products (Word, Works, etc.). But now, Windows Update for Vista will not work anymore for anything. At least switch to Windows 7 as Microsoft will probably support it until 2020.
SOURCE: power on NetDisk
try connecting the drive to a different system and see if that works.Incase it workd on another system than reinstall the USB drivers by going into the device manager.Also you could try different USB cords as there could be an issue with that as well.
SOURCE: win 7 64 bit freeze
I have the same problem. I don't have the right solution but I discovered a workaround.
The problem occurs everytime when I install a windows 7 update.
My work around:
Very suboptimal, but it works.
Anton
Try:
1.Set the drive to Share on the XP computer
Or
2.save all files you want to keep on xp computer, then put a MBR on external drive. (Should work between computers this way)
OR
3 . Save all files on xp computer,
Format external drive on xp computer, connect to new pc.
Windows vista (MY opinion) is junk . Keep xp or upgrade to windows 7 be my advice.
