, perform the following steps:
(power the machine OFF. Hold down the 2 and 5 keys, and power the machine ON).
2. Press P-4-7-P on the key pad. (1, 4, 5, or 6 will be displayed on the copy quantity indicator).
3. Press the 0 key to change the indication to a zero.
4. Press the start/print key to enter the new data.
5. Power the machine OFF then ON to exit .
Note: If the F code reoccurs after powering the machine ON or following warm-up, .you should have a tech check it out for you this is a fuser warm up issue
hope that helps
