HP Pavilion Media Center TV Desktop with AMD Phenom Processor 9500 Logo
Anonymous Posted on Mar 08, 2010
I have HP Pavillion M8330F desktop computer that the video card went bad in: Asus Geforce 8500gt Pci-espress x16 part #5189-2509. Will the HP/ASUS 512MB nVidia GeForce 8500GT video card be compatible with my computer
  • Anonymous Mar 08, 2010
    I only have 300 w power supply, is that enough? Also will the 512mb be a better video card?
    Will this video card be better than the other one? I only have 300w power supply, does that matter?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 20, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
402
Points
Am looking to install this card in a Gateway Computer DX 4850-45U
a) Can I do this?
b) there is a black/white thin wire coming off the card whith one white three hole connector. What is this wire and where on the mother board does this go to?
Anonymous
Level 3:
Guru:
  • Master 551 Answers
  • Posted on Mar 08, 2010
Anonymous
Master
Level 3:
Guru:
Answers
551
Questions
Helped
113665
Points
1166
If the 512mb nVidia is PCI-express then it is compatible. the point here the slot. if the slot is PCIE then the card should be PCIE also
    300W power supply is fine. actually that is the minimum wattz. if you have a 1gb video card it is much better. it gives a nice graphics and low consumption on memory.
2answers
What video cards fit into a gateway profile 6
You won't ba able to fit a video card in this computer. Because it is a all-in-one PC.
1helpful
Looking for a new video card for this model, having trouble finding one that will fit, any ideas?
any low profile video card with do. Try the following:
A) XFX NVIDIA GeForce 7300 GS Low Profile (Part # PV-T72G-WAN7, PV-T72G-****) $55
B) Visiontek Radeon X1650 Pro HD Low Profile (Part # V261-4038) $70
C) MSI NX8500GT-MTD256EH GeForce 8500GT 256MB 128-bit GDDR2 PCI Express x16 HDCP Ready SLI Supported HDMI HDCP Silent Heatsink Video Card - Retail $76.99
D) Leadtek WinFast PX8500 GT TDH Low Profile $131 (Available in Passive or with Fan versions)
E) Sapphire ATI 256MB X1600PRO HDMI PCI-E (TVO, DVI), Low profile (brackets included) $139
3helpful
2answers
I am replacing my NVIDIA GeForce 8500 GT Graphics card from my HP Media Center m8400f computer with a new NVIDIA GeForce GT 430 card. I have done this before and from what I have seen it is really...
If it is connected it will come loose. I believe it is for the cooling fan on the card. Be careful with pulling it out it is just a two part deal. You may pull the plug but it will also come off maybe in two pieces or one whole piece. Whichever it will come off. Give it some pulling. John
How do i install the asus geforce 8500gt 5189-2509?
1. Turn your computer off.
2. Disconnect the AC power-cord.
3. Remove the side-panel that is *NOT* closest to the keyboard/mouse connectors.
4. Unscrew the spine of the "old" video-card, and remove it.
5. Measure the distance between the "spine" of the video-card and the first of the gold-pins on the connector on the video-card.
6. Compare this distance with the "empty" slots on the motherboard,
to find a match.
7. Insert the new video-card, pushing until it is firmly seated.
If it does not seat, the video-card that you purchased is *NOT* compatible with the slot on the motherboard. Stop, and re-insert the old video-card, and re-assess the situation.
2helpful
Compatibility
Yes both of them are compatible, The 8500 GT uses a PCI X16 slot which is available on the m2n-mx motherboard.
Check these 2 links
http://www.amazon.com/Geforce-8500-Pcie-256MB-2PORT/dp/B000RKS3MU
http://reviews.cnet.com/motherboards/asus-m2n-mx-motherboard/4507-3049_7-32045049.html?tag=mncol;psum
HP Pavillion PC with Nvidia GeForce 8500GT freeze so often.
try enabling PCI option in the bios...
and also update your graphics card drivers for nvidia.com
1helpful
Installed GeForce 8500 GT PCI-E video card and pc will not turn on
If your mboard has a builtin video card you should configure that b4 u can use that add on card.
1. connect the add on card.
2. connect the monitor to the built in VGA.
3. start system and press "F2 or Delete" to go to bios setup.
4. on bios setup " refer to the manual on installing addon PCI express card".
you find it here: http://support.asus.com/download/download.aspx?SLanguage=en-us.
or enlosed in the board.
After configuring your system restart and unplug in the wall outlet and then connect the monitor in the add on card.
Hope you find in order.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
