Lands Phones Logo
Posted on Mar 07, 2010
How do I record a message for the telephone answering machine
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 08, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
166
Points
El problema es u no tengo tono cuandollamo al lugar donde estoy llamando esta mudo asi que no puedo hablar por favor si me pueden resolver este pequeno problema gracias
1helpful
Hi. My At&t Cordless 2 Hand set Telephone (EL52213) Answering machine (ON) doesn't record incoming messages. The Message window shows 0. The Telephone base is connected with my FAX machine (Teleph
If your Phone service is recording messages, that disconnects your line. You need to have them turn that feature off, OR set the answering machine to answer is less rings, say two or three. If the FAX machine listens to the line, it can still be set at a higher amount of rings, say four, and should still answer any FAX signal as it's sent to the answering machine.
KXTG9341 Top light flashing and 'New Voicemail' message on handset display, but no new message recorded on the answering machine.
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone.
Please contact your telephone company for instructions on accessing their voicemail system.
How to rerecord the answering message
What model Uniden DECT 6.0 phone/answering machine?
Are you sure the message in on your answering machine and not a voicemail system provided by your telephone company? Many telephone companies offer a voicemail system that takes messages if someone calls while you're already on the phone.
1helpful
Message lite staying on after all message are removed
When you say "all messages" are you referring only to the messages on your answering machine or are you including the messages on the voicemail system provided by your telephone company? This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
I have a Uniden cordless answer machine,Can my meesages be retived?
You can operate your answering system from a remote location using any touch-tone telephone. Use this function to check for recorded messages, to play or delete messages, even to record a new greeting message.
  1. Call your telephone number.
  2. During the greeting message, press 0 and enter your PIN code. By default, the pin code is "80" without the quotes.
  3. The answering system announces the current time and the number of messages stored in memory. Then you hear "To play incoming messages, press zero two. For help, press one zero".
Available commands are:
  • 0 then 1 Repeat a Message
  • 0 then 2 Playing Incoming Messages
  • 0 then 3 Skipping a Message
  • 0 then 4 Deleting a Message
  • 0 then 5 Stop Operation
  • 0 then 6 Answering System On
  • 0 then 7 Memo Record/Stop*
  • 0 then 8 Greeting Message Record/Stop*
  • 0 then 9 Answer System Off
  • 1 then 0 Help Guidance
1helpful
Code to retrieve messages
Here are the instructions you need to follow:
If you want to be able to play your messages from a remote location, you need to enter a two-digit Personal Identification Number (PIN) code (01-99).
To select a PIN, perform the following steps:
1) With the phone in standby, press [menu/clock] twice.
The system announces "Security code," and the current PIN code is announced as it is displayed on the base.
Then the system announces the instructions for setting the PIN code.
2) Press [volume/select/ ] or [volume/select/ ] until the desired number appears.
3) Press [set] to select the PIN code. You hear a confirmation tone, then the announcement "Security code" followed by the new PIN code is announced. After a few seconds, the system announces "To set ring time, press menu again."
Note: The PIN code is set to "80" at the factory.
Remote Operation
When you are away from home, you can operate your answering machine with any touch-tone telephone. Use this function to check for recorded messages, to play or delete messages, even record a new greeting message.
1) Call your telephone number.
2) During the greeting message, press [0] and enter your PIN code
3) The answering machine announces the current time and the number of messages stored in memory. Then you hear "To play incoming message, press zero two. For help, press one zero."
4) You may continue to listen to the voice prompts, or you may select a command from the following chart:
Command Function Command Function
[0] then [1] Repeat a Message [0] then [6] Answering Machine On
[0] then [2] Play Incoming Messages [0] then [7] Memo Record/Stop*
[0] then [3] Skip a Message [0] then [8] Greeting Message Record/Stop*
[0] then [4] Delete a Message [0] then [9] Answering Machine Off
[0] then [5] Stop Operation [1] then [0] Voice Prompts
* For Memo Record and Greeting Message Record functions, the first time you enter the corresponding command, it
starts the Recording function. If you want to stop the recording, enter the command again.
Note: Once you enter the remote access menu, you must enter a command within 15 seconds, or the
answering machine automatically hangs up and returns to standby.
5) After all of the voice prompts have been played, you hear intermittent beeps indicating that the system is in the
command waiting mode. You may enter another command at this time from the chart.
6) When you are finished, hang up to exit the system. The answering machine automatically returns to standby.
Turn on the Answering Machine Remotely
If you have forgotten to turn on your answering machine, you can turn it on remotely from any touch-tone telephone.
2) Wait ten rings until the system answers. You hear intermittent beeps.
3) Press [0] and then enter your PIN code. The answering machine announces the number of messages stored in memory. You hear "To play incoming message, press zero two. For help, press one zero."
4) Press [0] then [6] to turn the answering machine On. You hear the outgoing message and a confirmation tone.
5) Hang up the phone; subsequent calls will be answered by the system.
Help to record a message on my vtech answering machine.
The VTech 2460 is pretty much the same telephone as the AT&T 2455. Here is a link to the AT&T 2455's User's Guide:
http://telephones.att.com/docMgt/public/art/179/2455_manual.pdf
Information about the answering machine operation begins on page 23/36.
4helpful
3answers
Lucent Digital Answering Machine Model 1715
If you search for an AT&T Digital Answering machine model 1715, you will be sent to a free service with an abreviated manual.
4helpful
2answers
AT&T 1717 answering machine
Here is a link to your owner's manual: http://telephones.att.com/docMgt/public/art/162/1717_ATT.pdf It says: Recording Your Announcement Before using this answering system, you should record the announcement (up to one minute long) that callers will hear when the system answers a call. If you choose not to record an announcement, the system answers with a prerecorded announcement: ?Hello. Please leave a message after the tone.? 1. Press and hold ANNC/SKIP. The system beeps. Speak toward the microphone normally, from about nine inches away. While you are recording, the Message Window displays ?. 2 To stop recording, release ANNC/SKIP. The system automatically plays back your announcement. To review your announcement, press and release ANNC/SKIP.
Top Brother Lands Phones Experts
k24674
Are you a Brother Lands Phone Expert? Answer questions, earn points and help others
