American Standard Williamsburg Toilet Seat & Cover Logo
Posted on Mar 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I seems that the williamsburg 5395.700.20 toilet seat is no longer made. What can I use as a replacement
charles
Level 2:
Sniper:
  • Expert 97 Answers
  • Posted on Mar 08, 2010
charles
Expert
Level 2:
Sniper:
Answers
97
Questions
0
Helped
51417
Points
268
If it doesn't embarrass you, you could take the two nuts off the bolts holding the seat on, put the seat in a bag and take it to a Home Depot or Lowes or Walmart etc and match a new one to your old one. Good Luck
  • mary joan Sep 28, 2010
    You can buy one from THEM for about $200. --- NEVER BUY american standard again.
1helpful
2007 Fleetwood Williamsburg fold down cassette toilet won't work
If you're using water out of the fresh water tank then the toilet gets water from the same water pump the sinks and shower does. If they work OK then there's an internal toilet part that has broken.
Where can I find a toilet seat that fits an American Standard 2038 Williamsburg toilet? The company has stopped making a replacement and has not responded to my inquiry.
General Plumbing Supply has always come through for me...
Yelp only gives them a 3/5 but I have always had to wait with PROFESSIONALS to get my turn. I'm not big on ambiance when hunting for obscure plumbing parts..
BRING your old (always... any-parts) seat with you!
Amazon says $34 (plus tax)... Phenomenal return policy
A quick search on line yielded lots of other choices...
Happy hunting!
2answers
I need a toilet seat replacement of Porcher Veneto Toilet. The part number is 70030-00-001 and I'm told by Porcher is no longer available. They say no other seat fits. Any ideas? Where to find
I had the same issue and basically called every single american standard distributor I could find. I finally found one! They had the gold hinges but I didnt care, it fits and works fine. Make sure you know the part number. I had a good salesperson that knew to look for any color hinge so I had a seat
2answers
I have the porcher veneto toilet. I'm looking to replace the seat/cover. Veneto Elongated Toilet Seat Cover, part no. 70030.00 (white with chrome hinges) Is there a compatible cover the will work...
I too have the same toilet seat that needs replaced. Porcher just told me there is NO replacement seat that can be used and they no longer make nor have stock of this toilet seat. I have a local company looking into the problem and will get back to me. For now I am going to take detailed measurements of hinge placement and length/width etc, and take a tape measure to every home imporvement store in the area. Anyone with any other suggestion would be greatly appreciated.
I have a fluidmaster ballcock valve that sometime sticks and the water does not enter the tank. what could be problem
Well, something is amuck with the valve. What you do is jsut replace it. The plastic gets brittle, eventually.
There is also a chance that the shut off valve washer is causing issues. If the problem persists, look into that, also. The washer sometimes shrinks and will not remain open. It is an easy replacement fix.
Need to replace toilet seat and cover for a Williamsburg, white toilet. The part number I have is 5395.700.....but I have learned this number no longer exists. What number toilet seat/cover fits a...
Your toilet is still offered by the manufacturer:
http://www.americanstandard-us.com/toilets/williamsburg-one-piece-elongated-toilet/
Available replacement toilet seats from American Standard can be seen and ordered here:
http://www.americanstandard-us.com/repair-parts/toilet-seats/
You might consider finding you nearest dealer or choose another on-line retailer:
http://www.americanstandard-us.com/dealerLocator.aspx
Before ordering suggest you confirm with American Standard Customer Service the appropriate replacement seat for your model.
http://www.americanstandard-us.com/customerservice/onlineStoreSupport.aspx
Elongated toilet doesn't fit where a round toilet was installed
Hi. There are toilets designed to accept a round seat and there are other toilets designed to accept an elongated seat. The primary difference is that the round seat fits a round bowl and the elongated seat fits an elongated bowl.
I recommend that you return the elongated seat and exchange it for a round toilet seat. good luck
Top American Standard Home Experts
john h
Mike Cairns
Mike Cairns
deton8 von Splosion
Are you an American Standard Home Expert? Answer questions, earn points and help others
