I have a Onan 7000 genset in my rv It starts and runs using the inside start switch, The problem is I can;t shut it off from the inside. I have to go out to the generator and press the stop button on the generator. The inside switch appears to be working properly. Could the switch be wired wrong?/
Either you have a kill wire ( if I remember it is the brown wire) that is disconnected on one end or the other Or your in coach switch is bad.
Check the switch this way
Remove the switch from the dash/ mounting surface unplug the brown wire - start the genset - ground the brown wire - it should kill the motor
If it kills the motor your switch is bad
