Uniden Cordless Phone Logo
Posted on Mar 06, 2008
Displays new voice mail and VMWI constantly blinking when no voice mail
Model 28111 series DECT 6.0 Cordless phone. Handsets show new voice mail and the blue light (VMWI) constantly blinking when there is no voice mail-my voice mail subscriber is Verizon.
  • 6 more comments
  • Anonymous May 22, 2008
    Different model cordless 25952EE2, but displays NEW VOICE MAIL on handset. I had my name there at first in this mode. 0 messages on base unit....Instructions say NOTHING about voice mail
  • Anonymous Jul 20, 2008
    I have the opposite problem, also subscribe to verizon - have voicemail but no flashing light or message waiting display.
  • Im4tony Oct 16, 2008
    Same problem with Model 28213.
    Arrgghhh.....
  • Anonymous Nov 07, 2008
    Flashing light...no voice mail...aaarrhhhhhgggg
  • lrea307 Nov 12, 2008
    I have model 28112 6.0 Cordless. My blue light is blinking and I cannot turn it off. No messages on verizon.
  • Anonymous Dec 28, 2008
    I have the same problem (VMWI will not turn off). I currently have T-Mobile@Home. When I had Verizon (Copper followed by FIOS) it never came on.
  • Anonymous Jan 27, 2009
    Same problem with T-Mobile @ home. Not a solution, but first I made sure that the voice mail of TM@home was empty. Now I will try disconnecting the base and replacing with another phone for a few hours... maybe it will go away. I will post the result.
  • Anonymous Mar 15, 2014
    the handset on my cordless expanded verizon 500am dect 6.0 is blinking. I changed the batteries but it still blinks including that the phone does not work, yet still blinks
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 27, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3591
Points
24
Subscriber is T-Mobile@Home. First, cleared all messages from T-Mobile voicemail.
Now to fix your GE phone:
Push the program key. Select Handset Setup Push the program key Select Default Settings Push the program key Select 1 Yes. Push the program key
Hope this helps.
Anonymous
Level 1:
  • Posted on Feb 03, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3591
Points
I had flashing blue VMWI light with my 28821 series DECT 6.0 Cordless phone. As far as I understand this is the way how this phone reacts to "stuttering" dial tone which usually indicates a pending voice mail from the service provider (not the one from the phone answering system). After I made sure I cleared all voice mails from the provider (Comcast digital voice service allows you to do it via web), dial tone returned to normal and VMWI indicator stopped flashing,
Anonymous
Level 1:
  • Posted on Nov 12, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3591
Points
I have a Ge cordless phone model 28821. The blue light signalling voice mail continually flashes. Also my caller ID does not come across. I have tried unplugging everything and removing the batteries in all the handsets and that did not work. Canna anyone help me? I am tired of seeing the light flash at night. Thanks.
Anonymous
Level 1:
  • Posted on Apr 10, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3591
Points
On my Vtech 5.8ghz phone all it took was the "clear voicemail" option in the program menu. I'm sure most phones has a similar function.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on May 06, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4799
Points
10
You need to clear all your voice mails with YOUR CARRIER, not your base station. Example:  I use Comcast Digital Voice for my phone service. I logged on to comcast.net, and then went to my account to view all of my voicemails. Once I deleted all of them, the light STOPPED flashing on my 28821 model phone.
Anonymous
Level 1:
  • Posted on Dec 06, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3591
Points
I have a GE cordless phone model 27907. The orange light signalling voice mail is continually flashes now. The phone has been hooped up for about one month. No problems before. There is no voice mail on the phone and I no not have that service with my phone provider Mediacom. Can you help me turn this off. Thanks
Anonymous
Level 1:
  • Posted on Jul 20, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
3591
Points
I have the opposite problem - no voicemail waiting light or display when there is voicemail
3 Related Answers
Anonymous
  • Posted on Jul 06, 2008
SOURCE: out of range shows on main handset of cordless phone
Unplug the battery. Hold down The * (star) and the #(hash) keys simultaneously. Re-connect the battery, phone will beep and screen will be blank. Press the voicemail (righthand silver key under the lcd screen). As above EEPROM/RAM message will appear. Place handset on base and your problem is solved.
Anonymous
  • Posted on Nov 29, 2008
SOURCE: Uniden Ex18560 series cordless phone
when I have voice mail messages un-checked, it blinks steady. after erasing, it works right
Anonymous
  • Posted on Dec 21, 2009
SOURCE: one handset gives the message, blinking, Welcome!
I replaced the battery. It solved the problem.
Both my handsets on my new cordless show new message but there is not a message how do I delete it
need the make and model of the phone
the problem is more prevalent since the nbn roll out
on a uniden dect 6.0 the fix is found in the manual under resetting the voice message indicator
press the menu > answer set up
press the down arrow until Vmwi comes up
press menu
press the down arrow to get yes
save by pressing menu again then the end button
The red ID button keeps blinking even when I have no messages. How do I stop it
You might try to reset the Voice Mail Waiting Indicator ( V M W I ).
To reset the Voice Mail Warning Indicator
on the D1680 and similar handsets:
1. press [menu]
2. scroll down to "Global Setup", press [select]
3. scroll down to "VMWI Reset", press [select]
4. scroll down from "No" to "Yes", press [select]
5. handset will chirp, blinking lamp goes out,
6. press [END]
Other models, check your manual. The model number
is on a small sticker under the battery in the handset --
enter this number at www.manualslib.com to get a free
copy of the User's Manual.
HOW DO YOU ELIMINATE BLINKING ON HANDHELD UNIT
That might be the Voice Mail Waiting Indicator.
On the D1680 and similar handsets, it is reset by:
1. press [menu]
6. press [END]
Blinking light stays on after msgs have been deleted
That might be the Voice Mail Waiting Indicator which
is NOT part of the answering machine system.
On the D1680, D1481, and similar handsets,
it is reset (turned off) by:
1. press [menu]
6. press [END]
The answering system red blinking light is working on all three handsets all the time, even when there is nothing left on the answering system.
That might be the Voice Mail Warning Indicator.
1. press [menu]
6. press [END]
Read and deleted all messages. MessAGE LIGHT STILL BLINKS
That sounds like the Voice Mail Waiting Indicator.
1. press [menu]
6. press [END]
How do I turn off voicemail light?
To reset the Voice Mail Warning Indicator ---
(( On the D1680 and similar handsets ))
1. press [menu]
6. press [END]
How do I reset voice mail notification, have tried resetting global setup and VMWI reset but it doesn't stay long as red light starts blinking after a while and there no message?
You apparently have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
32helpful
5answers
New Voice Mail flashing light
press "mute" key to access menu, press the up or down arrow key labeled "caller ID- volume" until you get to "handset setup", press the "mute" key again, press the down or up arrow until you have "defaultsetting" selected, press "mute" key, press "1", then press "mute" once more. At this point your handset will reset clearing the indicator for all the handsets. I've had to do this twice on my phones and it worked every time.
3helpful
2answers
What worked for me was to call my phone from another phone and leave myself a voicemail. I then went in and retrieved and deleted that voicemail. Once I hung up from my voicemail service my handsets reset about 10 seconds later.
I hope this helps!
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
