There could be 3 different problems with this machine.
1) loose drive belt (this model has a spring loaded idler that tightens the tension)
2) Bad front drive roller (you wil hear the pulley spinning freely on the front roller if the roller is bad)
3)Last is possibly the walk belt itself. May need to be tightened or replaced.
To try to tighten the walk belt, go to the end of the walk belt and find the 2 adjust allan screws in the end and tighten them 2 revolutions clockwise on both screws.
Hope this helps a little. Tim
There are 2 allen screws on the rear of the machine. Use an allen wrench and access the side in which the walk belt is tracking towards. (tracking to the right go to the right screw) Insert the allen wrench and rotate the screw one revolution CLOCKWISE. This should move the belt 1/4 inch towards the center. If needed you may rotate the screw one and possibly 2 more revolutions but more than that you may have another issue with the machine.
Good luck! Tim
remove the two black screws near the power switch and the plastic switch section should come away from the frame. Inside you should find a yellow wire, if you find this is disconnected from the other yellow wire, plug them back together and you should find the solves your problem.
Have a 2 year old Reebok treadmill. Control panel was replaced right after we bought it. Now, again, the upper half of the panel works but we are not allowed to start anything. Does the whole panel need to be replaced again or is there a fuse or something small that we can do.
check your fuse on the lower board first. you may have damaged the lower internal board onthe treadmill. check the out let. Is there power on the head board?
