Yes, i've seen them for sale at online shops for $10 per pad. i've never changed any though. the sony's can be disassembled via phillip head screws. good luck.
The tan and black paper that is coming out of your printer is the Teflon fuser sleeve that has torn and coming apart. The fuser is the part of the printer that melts the toner onto the paper. The Teflon sleeve in the fuser is where the heat comes from. When the sleeve gets worn down it can tear and you get the little pieces coming out like you have. You will need to replace the fuser unit in the printer to correct this issue. The fusers are available from Amazon and other web sites and they are user installable. The part number is RG5-2657 or RG5-2661 either parts number will work in your unit.
Its possible. There is an equalizer valve that balances pressure to the 4 wheels. Two other possible causes are a problem with the parking brake, or the front rotors and pads are glazed and not providing any friction.
If they are new return them to where you bought them or contact the maker. You are entitled to your money back or a replacement. DO NOT attempt to fix them.
If this is happening all the time check the tires for a rock or something stuck in the tread. If this is only happening when you turn to the right check the CV shaft joints for excessive play or torn boots. You'll also want to check the boots if it happens all the time. If you have over 25,000 miles on the vehicle check the brake pads on the front end for wear since normally there is a "Chirper" on the pad that is supposed to start chirping when the pads are worn. On occasion the chirper will be just close enough to only catch the chirping path but not close enough to chirp or squeal like you would hear then the pad is seriously worn. Most likely this is a small rock or piece of road debris stuck in the tire, a torn boot or worn CV joint.
Yes, the replacement pad for mdr 7506 fits in for the v600. They can be replaced for one another. There are different types of v600 and 7506, You just have to look for the 7506 that looks more like the v600. That should do the job for you. Hope this information helped You.
Unless you have grooves in the rotors that almost gouge your fingernails, they should be good.
One indication of "needing pads" is, indeed, the loss of power; however, roughing them up CAN give you some more life, as it looks like you have pad material to work with. But if the roughing doesn't work, it's time for new....
...And I always recommend ceramic pads! Two years of awesome performance in my BB7's! Modulation is a step above ANYthing else I've used, and the stopping power is there all day long.
What do you mean by flexifoot, and what do you mean split? The large rubber disc is called the "durometer" disc (on the G3 it's called a finned disc). The small rubber pad the the big one fits over is called a "foot pad", the foot pad fits over a hard piece called the foot plate. That being said.... if your referring to the durometer disc being split, or torn, I assume it is very worn out and needs to be replaced. if it's new and torn then it may still work fine. if it is worn out chances are you need to replace the foot pad, and possible a couple other pieces.
On the DLC 7 Pro cuisinart the blade was removed by removing the plastic bottom. Make sure the unit is unplugged. Remove the four rubber pads on the bottom. This was the hardest part because the pads are glued so securely that the inner rubber surface tears as it's removed. I used two flat blade screwdrivers and worked carefully, back and forth. Using a #2 philips, remove the four screws. Place the unit on its side and while inserting a screwdriver between a spoke and the motor frame gently turn the blade counter clockwise. Be careful not to put pressure against the cooling fins. Very little pressure was needed and the blade came right out. I might have been able to hold the shaft from turning without removing the bottom, by going through the vent slots in the bottom, but I was concerned with cracking the plastic. To replace the rubber pads I matched the design of the torn rubber pad with the shape (design) of the surface glued rubber and used thin two-sided tape.
