I also have the same problem with water leaking out of the bottom.There is a defective hose underneat the burner plate (dry rotted)Mine is manufactured in 05.We contaced Cuisenart to make them aware of the problem and they told us nothing they could do it was out of warranty.After talking to 3 of there costumer service reps.my husband decided to take it apart and found the shredded hose leaking water on the electrical wires.That is why we contacted the CEO of the company and The Consumer product safety commision..They are handeling this issue.You can contact them also .
I've had the same leaking issue with mine since I got it in 2006! I haven't been that concerned about it, but maybe I should be! I have been more annoyed that the door pops open while in mid brew spilling out everywhere unless I'm there to make sure it stays closed. And also the hot plate has never been hot! I should have returned it in the first year but I was just too busy. I've forced myself to keep using it because it was so expensive. Now it does not brew all the water in the tank so I have to repeat the brew 2 or 3 times to complete the pot. Pretty disappointed that I put this coffee pot on my wedding registry. All I've seen on the internet is that Cuisanart will do nothing about any issues. How is your issue being handled? Thanks.
I have the same problems with mine - the water leak has gotten much worse so I'm replacing the coffee pot this month. I've also had issues with the door popping open while grinding. I usually have to hold it closed.
