https://postimg.org/image/ed118sfxx/
Click on the link.
Hope you can read it, I tried to get everything in one picture. Have you set the idle? The info is for setting the idle. I can give you the specs, but, I need engine size, also, is this automatic or manual tranny? Check fuel pressure if you haven't already, 9--13 psi, throttle body fuel injection.
How long since over-all tune-up? You can use digital multimeter to check throttle position sensor. Probe the dark blue wire at sensor connector, key on, no need to start it, then move throttle lever under the hood by hand, the voltage should move up and down smoothly. Closed throttle about .5v fully open about 4.5v.
There could be other issues?
As far as factory idle specs, if this is a high-mileage engine, those specs may not work very good?
