Yes, they don't make them like they used to and it is definitely worth fixing. Black dust is almost certainly the belt. Pull the machine out and tip it backwards against the wall. Have someone hold it steady and look underneath with a flashlight.
Worn bearings make a noise.
Parts 30 on drawing 1 is your belt. $39 Canadian. It is a long belt! Make sure the pulleys are okay and the motor and gearbox turn freely.
The spring that provides tension to the belt may not be strong enough. Replace the spring & the belt. You can get this parts from this site http://eapparts.partsquik.com/
If you are doing the normal procedures and the water elimination function is working, you have power to the circuit board and controls. The circuit board wash cycle section is independent and aligned with the timer circuit, thus the Wash Cycle Controller has failed. All of the functions or options are one the one board and a replacement board needs to be purchased and installed.
Snubber ring that tub and spin basket assembly sits in is most likely worn. Very inexpensive part but extensive labor involved. I would suggest calling a competent service tech.
Try leveling the washer... If the washer is level, then don't wrap the clothes around the agitator...drop the clothes straight in, on top of each other evenly around the agitator. The Ensignia washer has a Dual action agitator... That means the clothes roll over them selves, instead of moving side to side, as with a traditional agitator. wrapping the clothes around the agitator will cause the load to be un balanced and then cause the "banging" noise... this should take care of the problem...
