Is it a BIOS password or is it a Windows Logon password? I'll be ready to help you further as soon as I get a response.
OK, if it is Windows XP, you can start in Safe Mode to access the Administrator log-on. Usually the password for this is set to none unless you've set one up. To start in Safe Mode, hit F8 repeatedly once the computer is turned on until you get the bootup screen. You'll want to select Safe Mode.
Once you're in Safe Mode, go to Control Panel. Select User Accounts and select your User. Select reset password and type in your new password. You should then be able to restart the computer and log-in normally with the new password.
I'll wait to hear from you as to your success.
The password for Windows 7 Administrator is the original password you entered when you first purchased the computer and it asked for an administrator password. If you do not have that password, the only option you will have is to restore the system to original factory defaults (you'll lose everything that you've put on the computer if you do this). Windows 7 is very secure and there are no current programs to get around the password unless you created a password restore disk before this. In order to restore the system to original factory condition, press F10 when the HP Invent Logo appears. Follow the on screen instructions.
Hi,guy
Don't worry,To avoid reinstalling your system, the easiest way to resolve the problem is to use some Windows Password Recovery program. The program will enable you to reset the password to "Blank"; with no -reformatting or installation. reset Administrator password for you automatically.
just download the product form Password Recovery Official site http://www.recoverlostpassword.com/
For Windows 7, there is nothing much you could do.Follow 5 ways of Recovery explained in the below link :-
http://pcsupport.about.com/od/toolsofthetrade/tp/passrecovery.htm
Other than this, the other options could be playing with Hardware.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Thanks for your response!!
To access the recovery partition on your HP or Compaq computer for
recovery, follow the steps listed below.
1. Power on the computer
2.
Press F10 repeatedly when you see the HP or Compaq
logo.
2. When the recovery screen appears, press Next
and then Yes to perform a non-destructive recovery.
3.
To perform a destructive recovery, click Advanced and
then Yes.
4. After the recovery is finished, the
laptop will reboot.
If problem persists, you need to Contact Hp for Recovery Disk or you need to Reinstall the Windows using Windows 7 CD.
Let me know, if needed further assistance.
Hope i helped you.
Before i Found a Video for you, follow the below steps and let me know, if that could Fix the Problem.
1 Turn on the computer.
2 As the computer starts, press
Advanced Boot Options menu appears on the screen.
Note:
You must press
screen. If you press
screen, the Advanced Boot Options menu will not appear on the screen. If
you do not see the Advanced Boot Options menu, restart the computer,
and then repeat this step until you see the menu on the screen.
3 Press the
Computer on the Advanced Boot Options menu, and then press
4 Specify the language settings that you want, and then click Next.
5 Log in as a user who has administrative credentials, and then
click OK.
6 Click Dell Factory Image Restore.
7 In the Dell Factory Image Restore window, click Next.
8 Click to select the Yes, reformat hard drive and restore system
software to factory condition check box.
Hope i helped you.
Thanks
I Apologize, but these Methods would NOT work as you ultimately need Administrator's Password ( Password you Forgot ) to Restore / Reset the Computer and by Mistakenly, the last steps are for DELL.
Either you need to use 5 techniques Offered by Me Initially for HP. You could go for Recovery Disk / Re installation of Software.
Hardware Fix
Look at the Video. Just Pull out the CMOS Battery and it would Reset the password.
Generic Procedure is :-
Hope i helped you.
The link for Video is :-
http://www.youtube.com/watch?v=cmHtjY39i...
Hope i helped you.
Thanks
Lost windows password is not a big problem .I realize an easy method to reset lost windows password, just need to produce a windows password reset bootable CD/DVD or USB flash drive to reset forgotten windows password,I have made a bootable USB flash generate using the tool Windows Password Seeker and reset my administrator password successfully.More information in http://www.passwordseeker.com
To avoid reinstalling your system, the easiest way to resolve the problem is to use some Windows password recovery program. The program will enable you to reset the password to "Blank"; with no -reformatting or installation. reset Administrator password for you automatically.
If the password that you forgot from your user account is standard and not administrator then i can help you. just follow my instruction. restart your pc, before the windows appear just press F8 then select start in SAFE MODE, then login by clicking administrator that you found in login screen(this appear when you start windows in SAFE MODE). once you are already login, go to user account in control panel then manage those account that you forgot the password, just click that user account then click remove password then after that click create password. that's it.
Usually this works for me
turn off your pc then turn it on hit F11
keep clicking til it goes to welcome screen then type in administrator leave password blank it should let you in then go to accounts and change your password there
hope this helps
it is a windows logon password
my computer is a hp windows 7. i went to safe mode but it still took my to the sign on or log on screen, still asking 4 my password.
i have a hp windows 7 laptop and i forgot my password. can't log on cos is asking 4 my password. what do i do please?
i pressed f10 to make it go back to it's original factory standard but don't know what else to do, cos am not seeing anywhere it says relaod to factory standard.
i hit f10 like u said and it took me to a screen called "MAIN SECURITY DIAGNOSTICS SYSTEM CONFIGURATION" i don't know what else to do?
i did exactly what u said, but is still asking for my administrative password.
sorry i didn't see any video.
