Question about HP Compaq Presario CQ50-110US Laptop
It doesnt charge, i cant tell if its the charger or the laptop itself. it seems like something is loose inside the computer but i dont know
    Scholar:
  • 84 Answers
If you have a multi-meter, you can find out if the charger is giving voltage. On the "block" portion of the charger, it should have the output voltage (i.e., Output: 15VDC 1.3A). Using the multi-meter, look to see if you are getting 15V DC power
If you are getting power, the problem is with your main board. Also, inspect where the connector goes into the back of the unit...does the connector go in loosely? If so, it's likely the mainboard.
Posted on Mar 07, 2010
SOURCE:
Why cant charge but the orange light will appear
Please check on the following. Check for any physical damage on the charger port, the charger itself, if it seems to be loose when the chargers plugged in or for any foreign material that might be blocking it from the inside. Test it if it will also charge from another charger or a known good working power outlet. You can also try to drain out power by pressing and holding the power buttonon your device for 10-15 seconds. Hope this helps.
Sep 14, 2013 | Computers & Internet
I have a Gateway MT6220b laptop and it is not charging properly. The charger charges intermittendly. Sometimes it does, someimes it doesn't. It seems to charge if you hold the charger in tight,in the...
Seems that something must have bent the connector inside the laptop itself. If you are knowledgeable enough you could see for yourself but I would take it to someone for an estimate to see if it's worth your time and trouble having it worked on at that level.
Mar 24, 2011 | Amstron Gateway MT6220b Laptop AC Power...
I have a compaq presario cq61 and have been having problems with the charger for quite a while but money is an issue so cannot get a new one just yet, the laptop has 2 lights to aknowledge that the...
YOUR PACK IS NO GOOD
IT MUST RUN WITH NO BATTERY
PACK CONNECTED
SINCE IT DONT THEN THE CHARGE IS WEAK TOO.
YOU KNOW PACKS CAN BE
GOOD
BAD
OR WEAK, OR EVEN ON FIRE, (loL)
Mar 01, 2017 | HP Compaq Presario CQ61420us Notebook
My Samsung R40 will not charge. The cable/charger
it is called the AC power Wall Socket is that what u r talking about do u think u can replace it i think u should call some elec guy to fix it like maintenance guy it has nothing to do with ur notebook its just the pins inside the socket got loose and ur plug is unable to stand in there am i right pls vote if u find me helpful
Feb 22, 2009 | Samsung Computers & Internet
Optio a10 charger
if you don't see a light on the charger lite up its the charger, or the internal batteries are no longer excepting the charger. my first guess is the charger itself.
Sep 25, 2008 | Cameras
Compaq presario v2000 wont charge
It has happened to me as well since i have the exact same model laptop. The problem is a loose cable or the wire inside is damaged. I just bought a new charger since buying one is cheaper than taking the risks that the repair might cause a short after using it for some time.
Jul 26, 2008 | HP Compaq Presario V2000 Notebook
Laptop Power
Not the charger. It is either the battery or the charge circuit in the laptop. Most are on the mother boards but some have a changable dc to dc inverter board
May 13, 2008 | Acer Aspire 5100 Notebook
Acer 5050 screen blink...AC problem???
Very likely a problem with the connection between the power pack and the laptop itself. This is usually the weakest point, and often you need to wiggle the connection a little to get a good connection.
It is usually just a solder joint that breaks, but it is a lot of work to get fixed on most laptops so get it replaced under warranty.
Jan 13, 2008 | Acer Aspire 5050-3242 Notebook
HP Compaq Presario CQ50-110US Laptop Logo
64 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
