Pioneer VSX-D912 Receiver Logo
Posted on Mar 07, 2010
Having problems getting sound to my two rear speakers out of the amp pioneer VSX-D912 6 channels
5 Related Answers
bengsoon Neo
  • 63 Answers
  • Posted on Aug 03, 2007
SOURCE: pioneer vsx d512
All you have to do is connect the coaxial out from pc to any audio i/p at the back of vsx d512.but ensure you select the right channel to play the audio ( eg. tape i/p select tape at front control, aux i/p select the aux at front control )
Anonymous
  • 1512 Answers
  • Posted on Nov 08, 2008
SOURCE: Pioneer vsx-d902s
Hi Tracey
Most of these older machine had speaker switches on the front panel. Can you check what they are set to. It may be that both switches(A and B) are set in, or set out. this could present the problem you are having with no sound. turn on just one switch that corresponds the connections you have made on the rear (use speaker A) Another thing to check, is when you first turn on the amp, do you hear a relay click shortly after you switch on. If you don't hear this delayed click, then there may well be a problem in the output stages of the amp. If this is the case, then you will need to take it to a tech to have a look and see what has failed in the amp. Hope this info helps, if you have any questions, I am happy to try and help you further.
regards
robotek
Gustavo M.
  • 30 Answers
  • Posted on Apr 02, 2009
SOURCE: pioneer receiver vsx d814 amp error
The Pioneer VSX-D814 has a couple of Power Hybrid bricks that do all the power amplification. These are the infamous PAC011A. You should have 2 of those in your receiver.
If the amp detects some unusual activities, it may shut down the unit to prevent damage. “Amp Err” usually means some DC in the output.
Disconnect all the speakers and turn on the unit; if it acts normal, reconnect speakers one set at a time very carefully. If the unit still shows the error message you can try to reset it. If the reset works, again carefully reconnect the speakers connections. If the reset does not recover the normal operation of the unit, you may have one of the PAC011A damaged, and the unit will need repair.
The reset can be done by disconnecting the unit power cord for a few minutes, then plug it in and press “FRONT ENTER key + ADVANCED SURROUND key” continuously for 2sec.
Good luck
Ken Ellis
  • 70 Answers
  • Posted on Oct 23, 2009
SOURCE: Problem for Pioneer VSX-818V-K 5.1 Channels
Test with an surround sound media ie. Blu-ray or DVD)_. Disconnect the front and all other speakers that are working to see if sound from the missing speakers are heard. If this doesn't work then start by tracing and checking all the wires from the receiver to the speakers for bad/shorted/open connections.
PLEASE VOTE IF THIS WAS HELPFUL. THANKS & GOOD LUCK.
Anonymous
  • 8546 Answers
  • Posted on Jul 06, 2010
SOURCE: My Pioneer vsx-49txi has lost its front center
Maybe you have Direct Playback mode selected. It puts the unit in stereo.
REAR SPEAKERS ON PIONEER VSX-401
@Michae Yokeum
"Rear Speakers on Pioneer VSX-401".
Hi Michae.
Wow, nice Hi-Fi!! :) :)
IF [manual_required] THEN
GOTO
https://www.pioneerelectronics.com/StaticFiles/Manuals/Home/VSX-01TXH_OperatingInstructions0523.pdf
ELSE
Check your SBch* setting which should be set to ON or AUTO.
*Speaker Back channels
More info on pg. 83 of manual.
PS - as this is a home hi-fi and not a car-radio, I've moved it from 'Cars & Trucks' to a new home 'Audio Players../Pioneer', where experts in that field can offer more help.
Why is it intermittently losing channels...front speakers and or rear surround?
How to troubleshoot low sound or no audio from the rear ...
https://us.en.kb.sony.com/.../how-to-troubleshoot-low-sound-or-no-audi...
Aug 15, 2015 - Verify that the rear surround speakers are properly connected to the ...For Dolby® ProLogic surround sound, the center-channel mode must be set to ... the center or rear surround speakers for the Home Theatre (HT) system.
Why Are My Speakers Producing Static? - Electronic House ...
www.electronichouse.com/.../home-audio/why-are-my-speakers-produci...
Here are 3 reasons that speakers produce static and solutions you can try. ... If they are your dedicated front L/R channels speakers in a 5.1 or 7.1 system, you more ...Since you have no problem with your existing rear speakers, if they begin to distort on... Home Theater Subwoofer Puts Boom in This Room · Soundbase vs ...
How to Check if your Speakers are Wired Correctly ' Richard ...
www.richardfarrar.com > Podcasting
Mar 25, 2009 - Attaching speakers to your Hi-Fi system usually only requires a few cables. ..... Is this test applicable for a home theater setup with 5 speakers? ... frontstereo speakers, but to do a similar test on your rear surround speakers would ... Yes, switching polarity on one channel of the amp output to your speakers ...
Pioneer VSX-816 speaker drop out - AVS Forum ' Home Theater ...
www.avsforum.com/.../1068233-pioneer-vsx-816-speaker-drop-out.htm...
Sep 20, 2008 - 30 posts - ‎24 authors
The right front speaker sound drops out intermittently as of about 6 months ago. ...mode and back to Auto Surround would bring the center channel back. ... the push pin that holds several grey wires in place, and pull the wires loose. 9. ..... Is it possible that the cold joints are elsewhere in the system, but that ... Yamaha RX-V663: Intermittent/No Audio in Front ...
Jan 23, 2014
Sony Receiver going in to Protect Mode
Jan 12, 2012
The Official Sony STR-DH820 Thread
Aug 29, 2011
Denon AVR-1910 - No more sound.
Feb 15, 2011
More results from www.avsforum.com
No sound out of the pioneer vsx-1121-k
Try removing all the speaker and the HDMI connections; then use a headphone to listen to music from the tuner or a CD in stereo mode. Better in direct mode. If you hear your music correctly the receiver could be working correctly. If no music is heard, you may need to have it repaired professionally.
If you can hear music, connect the main FL & FR speakers and verify you can hear music that way, without the headphone connected.
If you can hear music that way, connect the center and rears. Try a mode that uses all channels to verify all sound channels are working.
Then, and only then start adding your HDMI connections.
Good luck
Connectivity
you have to make sure you are on the theater mode on your amp. that's the only time that the center speaker works
2helpful
2answers
No sound of voice, only surround sound
If you do not have a center channel speaker connected, then in the reciever setup menu for speakers, there should be a selection for center channel that says something like either yes or no. I'm guessing it says yes. Then you need to select "no" so that the circuitry will direct sound specified for the center channel to be reproduced through your front speakers.
Problem for Pioneer VSX-818V-K 5.1 Channels Receiver Surround sound doesn't work, display reads 2CH IN,surround speakers are enabled,automatic test will find surrand speakers
2answers
Amatuer needs sub-woofer advice for Pioneer VSX-454...
Based upon your description, the subwoofer is just a speaker and is taken from the normal speaker outputs. Run your A channel to the sub and then from the sub to the left and right front speakers. That should do it.
Dan
2answers
Pioneer vsx-5300 reciever
sounds like an internal problem.
By chance were you running speakers on the "a" and "b" front channels at the same time? If so...over time this load can be too great and eventually wear out or overload the channels inside of the receiver. If not, could be something else internal, or possibly worn out of the age of the receiver.
Hope this helps.
Center channel
Just to rule out the easy solutions, have you made sure no settings changed? Make sure that you didn't accidentally turn off any surround sound settings or turn off the center channel in the MCACC setup or the like (I have the VSX-D814, so your receiver should have MCACC as well). If you're sure no settings changed and the center channel should be working according to the receiver, then it would appear that the center channel amp went out in the receiver. You can either get a Pioneer service center to take a look at it, or if you're comfortable with electronics, I believe you can get the parts straight from Pioneer.
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
