Nikon D90 Digital Camera with 18-105mm lens Logo
Posted on Mar 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Locating the D90 body serial number
Where is the D90 Serial Number located for the body?
Glyn Kendall
Level 2:
  • Expert 146 Answers
  • Posted on Mar 07, 2010
Glyn Kendall
Expert
Level 2:
Answers
146
Questions
0
Helped
53188
Points
435
It is on the base of the camera in the square with all the logos in, it is the last line.
It looks something like:
6000016
Hope this helps.
1helpful
Fender Squier Stratocaster serial number CY01084527. What year was it made and the value please?
Your squier guitar is from 2001
Says the last link. For value, check eBay sold listings.
Serial Number Lookup
Fender Guitars https://serialnumberlookup.fender.com Fender is proud to now offer self-service serial number search function. Feel free to bookmark the link for future reference, and please be aware that not every ...
Serial Number Tracking
Squier Wiki http://www.squierwiki.com > Serial-Number-Tracking
The serial number is printed on a sticker located on the back of the neck, close to where the neck attaches to the body. Because the number was placed on a ...
Squier Serial Number Lookup
Authority Guitar https://authorityguitar.com > squier-serial-number-loo...
Mar 8, 2023 - It's simple enough with our squier serial number Checker. Type your serial numbers into the decoder below and you'll get all the information ...
Squier Serial Check
Squier Serial Check http://guitarcheck.info Squier Guitar Check (1982 - 2011). Serial number. Serial Number should be 6-12 characters. Serial Number is required. Country of origin. Select Country, CHINA ...
I have an on old Cobra 86 KLR with a microphone
I can certainly help you try to locate the serial number on your Cobra 86 XLR microphone. The serial number is usually located on the bottom or side of the microphone body, or it may be stamped into the metal body of the microphone. It is also possible that the serial number is located on the bottom or side of the microphone base or on the microphone's packaging or documentation. If you are unable to locate the serial number on the microphone itself, you may want to try looking for the serial number on the documentation or packaging that came with the microphone, or on the manufacturer's website. If you are still unable to locate the serial number, you may want to contact the manufacturer for further assistance.
Jan 04, 2023 • The Music
1helpful
Where on the body of my homelite chain saw can I find the serial number! SuperXL 910 used to have a rubber insert?? +- 1971?
Your Home lite equipment will have a model information plate located on the unit. (silver colored) It includes the model number and the serial number. First model no - UL and then below it is the serial number. Check the handle.
11.5 Briggs Straton Poulan riding mower, location of MFG serial number
Depending on which your needing. The body model and serial decal is usually located either on seat or on the body under seat.
If it is the engine it depend if OHV or a L-head engine. OHV serial (date code) is on the valve cover. L-head is located somewhere on the engine's flywheel shroud.
How to check service tag on supermicro servers
AFAIK Supermicro is not using Service tags like Dell or Lenovo. Instead they go by serial numbers. The location of the serial number depends on the type of the server:
Blade serial number (SBI... or SBA...) is located on the side
Blade Enclosure serial number (SBE...) is located on the rear side
CMM (chassis management module) serial number (SBM...) is located next to the latch
Rack-mountable chassis serial number is located on side of chassis by the sliding rail
4U Tower Chassis serial number sticker is located on the bottom side
Rack-mountable Systems' Serial Number is located at the rear side by I/O panel
Embedded Systems' Serial Number is located on the I/O panel
Check this website for more:
http://www.supermicro.com/support/SNGuide.cfm?sn=ss
Gibson guitar serial lookup 02843656
From the SN alone, it appears to be a 2003. Gibson quite frequently used the first and fifth number of the serial to tell you what year the instrument was built in. But this completely depends on the model/ where the serial number is located/ if it is stamped, embedded, or located inside of a hollow body. If you can post a picture of the guitar and the serial number that would greatly help.
Sep 03, 2014 • Music
Hart cart atv location model sreial number
  1. Appliances (e.g., refrigerators, dishwashers, etc.): The model and serial number are typically located on a sticker or plate on the back, side, or bottom of the appliance.
  2. Electronics (e.g., TVs, computers, etc.): The model and serial number can usually be found on a sticker or plate on the back, bottom, or side of the device.
  3. HVAC systems (e.g., furnaces, air conditioners, etc.): The model and serial number are often located on a sticker or plate on the exterior of the unit, or on the inside near the blower or evaporator coil.
  4. Power tools and equipment: The model and serial number can typically be found on a sticker or plate on the body of the tool or equipment.
  5. Vehicles: The model and serial number (also known as the VIN, or vehicle identification number) can usually be found on a metal plate on the dashboard or door jamb.
If you're having trouble locating the model and serial number for a specific product, check the user manual or the manufacturer's website for guidance.
1helpful
2answers
Where is the model serial number on the Canon MX882
Issue: Where is the serial number located?
Solution: Locate the serial number MX882
Locate the Serial Number The serial number of the MX882 is located inside the printer, as shown below.
  1. With the printer powered on, open the Paper Output Tray (A).
    The above illustration shows a PIXMA MX870.
  2. Lift the Scanning Unit (Cover) (B) and fix it with the Scanning Unit Support (C).
  3. Wait until the print head carriage moves to the ink tank replacement position.
  4. To the right of the print head carriage, inside the printer, is a white sticker that is attached to a metal plate. The serial number is located on the white sticker. Please see the illustration below.
    The serial number starts with four letters and ends with five numbers, for example: ABCD01234.
1helpful
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
