Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer Logo
Posted on Mar 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I make the Maytag Centennial 3.2 agitate while the lid is open? I want the clothes to wash and just let them soak, not rinse immediately after agitating; without the trouble of watching the process.
  • Anonymous Mar 29, 2014
    wash but it will fill up to rinse and will spin
Anonymous
Level 3:
  • Master 576 Answers
  • Posted on Mar 07, 2010
Anonymous
Master
Level 3:
Answers
576
Questions
0
Helped
203990
Points
1663
You really can't without redesigning the washing machine.
2011 Maytag Centennial. It starts to agitate while the water fills in the beginning of the cycle.
Does it fill with water to the correct level? The water pressure switch lets the machine fill to a certain level and the stops the water coming in, then the control board should start the agitation.
The first video might help you.
https://www.google.com/search?q=Maytag+Centennial.+It+starts+to+agitate+while+the+water+fills+in+the+beginning+of+the+cycle
2answers
Clothes wrapping around washing machine agitator.
This issue could be caused by a number of things. It is possible that the clothes are not properly balanced in the wash drum, causing them to wrap around the agitator. It could also be a problem with the agitator itself, or with the transmission.
Maytag centennial top loader i left the lid open to soak some clothes and it drained on its own and now it is stuck in draining mode
Turn the machine off. Wait 2minutes close lid and start new cycle.
check to see if your drain hose is lower than the bowl....this will also cause the water to drain out
I have a maytag centennial washer MVWC400XWO it is 3 years old. The washer has stopped after the initial wash cycle leaving the cloths wet in a tub full of water. The washer will not go to the spin/drain...
For saftey the lid lock and lid down switch must be activated before the machine can advance to the next cycle. This has been the sequence for all top loaders..
Check the switch for the lid it is likely defective.
Make sure that the power is removed.
Simple repair by a qualified technician.
Hope this helps?
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
