Here You are...
Grand Cherokee fuses
1999-2004
Junction Block
Cavity Fuse Color Description
F1 -- -- Spare
F2 -- -- Spare
F3 10 Amp Red Headlight high beam left
F4 15 Amp Lt. Blue Flasher, hazard switch (see Junction Block diagram above for location of turn signal Flasher relay - Mopar p/n 4686094)
(Repair tip: WJ flasher repair)
F5 25 Amp Natural Radio amplifier
F6 15 Amp Lt. Blue Park lamps
F7 10 Amp Red Interior lights
F8 15 Amp Lt. Blue Overhead console, rear wiper, IP lights, rear flipper glass solenoid, power locks
F9 20 Amp Yellow Power outlets
F10 20 Amp Yellow Adjustable pedals (2002-2004 only)
F11 10 Amp Red Rear window defrost indicator
F12 10 Amp Red Auto shutdown relay / "Fuel"
F13 -- -- Spare
F14 10 Amp Red Headlight low, left
F15 10 Amp Red Headlight low, right
F16 10 Amp Red Headlight high, right
F17 10 Amp Red Instrument cluster, diagnostic connector
F18 30 Amp ? Trailer tow
F19 10 Amp Red Anti-lock brakes
F20 10 Amp Red Ignition Run / Heated seats / A/C Heater control / Flasher - Left and Right turn signal switch sense
F21 10 Amp Red Ignition Run / Start - PDC (Power Distribution Center)
F22 10 Amp Red Ignition Run / Start
F23 15 Amp Lt. Blue Brake switch
F24 15 Amp Lt. Blue Foglamps
F25 20 Amp Yellow Accessory delay relay (sunroof)
F26 15 Amp Lt. Blue Cigar
F27 15 Amp Lt. Blue Rear fog (export)
F28 10 Amp Red Body Control Module, Acc/Run
F29 10 Amp Red Rear wiper switch. Washer motors
F30 15 Amp Lt. Blue Radio
F31 10 Amp Red Ignition Start
F32 10 Amp Red Ignition Run / Start - Airbag
F33 10 Amp Red Ignition Run / Only - Airbag
C1 20 Amp Yellow Wiper (Circuit Breaker)
C2 20 Amp Yellow Seats (Circuit Breaker)
C3 -- -- Spare
