Hello.
Unfortunately, have not heard of this problem with this model.
Have you tried removing and reinserting the battery ?
Or, is it possible to downgrade to an earlier version ? Probably better to wait for the response from the manufacturer.
Hope this helps.
If you tried upgrading the software to Windows Mobile 6.1, there could be a possibility that the software is not compatible with the phone, or it could be corrupted.
First, verify the supported program of the phone. Next, check your the current program running on the phone.
Contact the manufacturer to ask them, what version of program that would work best with your phone. The only thing that you may try is to upgrade the firmware of the phone.
If you're going to think, draining the battery fast has something to do with the physical connection only, but the truth is, software or firmware is also responsible for that. Once you upgraded your software, there are some components that will work fast, that might cause the battery to drain out.
Contacting the manufacturer for second opinion is the best thing to do.
Thanks for your response. The problem seems to have arisen about three weeks after the upgrade to 6.1. The manufacturer has been contacted, awaiting response. In the meantime, has anyone else ever heard of this problem? I'm coming up empty on Google...
I tried a hard reset already. It comes back up in 6.1, re-updating is not an option.
