Had a Bunn BT10B about a week. if i fill with 50 ounces of water and 4 1/2 tablespoons of dunkin donuts ground coffee the basket overflows! I'm still using the filters that came with the coffeemaker. The sprayhead seems to be tight.
Try taking the filter out, and turn the sprayhead off the unit. Put the basket back on, and try pouring clear water through the unit. If the water runs through fine, you either have a plugged sprayhead or are using too finely ground coffee. Look at the holes in the sprayhead, and make sure that none of the holes are plugged. If the basket still overflows, try using a drill bit to make the hole in the funnel a little larger. Good luck.
Yes, you can use Miracle-Gro Water Soluable Plant Food in the Ortho Dial N Spray hose-end sprayer. Simply set the dial on the Dial N Spray to 4 ounces. The label rate for Miracle-Gro All Purpose Plant Food is 1 tablespoon per gallon of water. To make 8 gallons of finished spray, measure 8 rounded tablespoons of plant food into the Dial N Spray jar and fill the jar with water. Mix thoroughly. Set the dial at 4 ounces. When you have sprayed until jar is empty, you will have applied 8 gallons of properly diluted spray. Hilary@Scotts
