Hi. This isn't a quick repair. Procedure is to raise wheel off ground, place jack stand in place (for safety), remove brakes to expose axle, remove (4) axle retaining bolts and slide hammer to remove axle. A race removal tool will be needed to remove the old race from the axle shaft. You will buy a new axle seal, bearing and race. NOTE: Press the old bearing off first. There are two sizes plus if the retaining plate or retaining ring get damaged. you won't be surprised. A parts store or hydraulic should be your "Go To Place" for pressing off the old bearing and pressing on, the Retaining plate, new seal and bearing and retaining ring. Clean the axle shaft and install the new race and put it back together. If you need anything else please write back. Details are always good. Don't worry about saying too much. Good Luck.
If your familiar with this repair there are no tricks. It involves removing the rear differential cover, removing the spider gear lock pin and retainer clip from the axle shaft before removing the axle shaft from the Jeep.
To replace the bearings, you need to first remove the axles by removing the diff cover, taking out the small bolt or drift pin that holds the spider gear shaft in place, removing the shaft and pushing in on the axle to remove the "c" retainer on the axle end. You can remove the bearing by prying it out using the end of the axle or by using a puller made to do that. Install is the reverse of removal. Don't forget to re-fill diff before driving!
To remove the rear axle to replace a bearing you have to remove the rear differential cover and remove the small retaining bolt holds the spider gear shaft in place and then slide this shaft out far enough to remove the "C" shaped axle shaft retaining clip. Once this clip is off then the axle can be slid out and the bearing & seal replaced. Make sure that none of the spider gears or thrust washers behind them get out of place and you should use a new retaining bolt when reassembling the differential components as they come [or should come this way] with thread locker to prevent them from coming loose.
YOU HAVE TO SAFELY RAISE SUPPORT VECHICLE MAKE SURE ITS ON A SOLID LEVEL GROUND.THEN YOU REMOVE THE WHEELS THE BRAKE DRUM OR DISC.THEN YOU REMOVE THE NUTS THAT ATTACH THE OUTER SEAL RETAINER AND BRAKE BACKING PLATETO THE AXLE SHAFT TUBE.DISCARD THE NUTS.REMOVE AXLE SHAFT FROM HOUSING.WITH AN AXLE PULLER ATTACHED TO A SLIDE HAMMER.DISCARD INNER AXLE SEALPOSITION THE AXLE SHAFT IN A VISE.REMOVE THE RETAINING RING BY DRILLING A 1/4 HOLE ABOUT 3/4 OF THE WAY THROUGH THE RING. THEN USING A COLD CHISEL OVER THE HOLE.SPLIT THE RING.REMOVE THE BEARING WITH A ARBOR PRESS DISCARD THE SEAL AND REMOVE THE RETAINER PLATE.TO INSTALL - CLEAN THEN APPLY A THIN COATING OF WHEEL BEARING LUBRICANT TO THE BEARING AND SEAL CONTACT SURFACES APPLY WHEEL BEARING LUBRICANT TO THE LIPS OF THE REPLACEMENT INNER AND OUTER SEALS.INSTALL THE INNER SEAL WITH THE OPEN END OF THE SEAL FACING INWARD ENSURE IT IS COMPLETELY SEATED.INSTALL THE RETAINER PLATE AND THE OUTER SEAL ON THE SHAFT.ENSURE THE OPEN END OF THE SEAL FACES TOWARD THE AXLE SHAFT BEARING.PACK THE REPLACEMENT BEARING WITH WHEEL BEARING LUBRICANT AND POSITION ON THE AXLE SHAFT PRESS INTO PLACE.PRESS A REPLACEMENT BEARING RETAINER ON THE AXLE SHAFT AGAINST THE BEARING.INSTALL THE AXLE INTO THE AXLE TUBE.POSITION AND ALIGN THE SEAL RETAINER AND BRAKE SUPPORT PLATE AND INSTALL REPLACEMENT ATTACHING NUTS.TIGHTEN NUTS TO 32 FT LBS.INSTALL BRAKE ASSEMBLY WHEELS LOWER VECHICLE. YOU SAID REAR BEARINGS IF THIS WHAT YOU MEANT.I HOPE THIS CAN HELP.
Section 05-02A: Axle, Integral Carrier — 8.8-Inch Ring Gear
1994 Town Car, Crown Victoria/Grand Marquis. Workshop Manual
REMOVAL AND INSTALLATION
Axle Shaft
NOTE: Whenever replacing the rear axle lubricant, use Rear Axle Lubricant XY-90-QL (ESP-M2C154-A) or equivalent. Removal CAUTION: The rear brake anti-lock sensor must be removed before the axle shafts are removed. The rear brake anti-lock sensor is bolted on the rear disc brake caliper anchor plate.
Raise vehicle to desired working height. Refer to Section 00-02 . Remove rear wheel (1007) and tire assembly. Remove rear disc brake calipers (2552) and rear disc brake rotors (2C026) .
Clean all dirt from area of axle housing cover with a wire brush and/or cloth.
Drain rear axle lubricant by removing the axle housing cover .
Push flanged end of the axle shafts toward the center of the vehicle and remove the rear axle shaft retaining u-washer from the button end of the axle shaft .
Remove axle shaft from the rear axle housing , being careful not to damage the inner wheel bearing oil seal (1177) and rear brake anti-lock sensor ring.
Installation NOTE: Check for presence of rear axle shaft o-ring (4A332) on the spline end of the shaft and install if not present. CAUTION: Care must be taken not to let axle shaft splines damage oil seal or bearing assembly.
Carefully slide axle shaft into rear axle housing without damaging rear wheel bearing (1225) or rear brake anti-lock sensor indicator (2C189) . Start splines into side gear and push firmly until the button end of axle shaft can be seen in the differential case .
Install the rear axle shaft retaining u-washer on the button end of the axle shaft splines, then pull the shaft outboard until the shaft splines engage and the rear axle shaft retaining u-washer seats in the counterbore of the differential side gear .
Position the differential pinion shaft through the differential case and differential pinion gears , aligning the hole in the differential pinion shaft with the lock bolt hole. Apply Rear Axle Lubricant to differential pinion shaft lock pin . Install differential pinion shaft lock pin and tighten to 20-41 Nm (15-30 lb-ft).
CAUTION: Differential pinion shaft lock pin must be tightened to specification using Stud and Bearing Mount E0AZ-19554-BA (WSK-M2G349-A1) or equivalent.
NOTE: Axle housing cover must be installed within 15 minutes of application of the silicone rubber or new silicone rubber must be applied. CAUTION: Make sure machined surfaces on both axle housing cover and rear axle housing are clean before installing the new silicone sealant. Inside of axle must be covered when cleaning the machined surface to prevent axle contamination. Tighten the cover bolts in a crosswise pattern to ensure uniform draw on axle housing cover .
Apply Silicone Rubber D6AZ-19562-AA or BA (ESB-M4G92-A or ESE-M4G195-A) or equivalent. Install axle housing cover and tighten retaining bolts to 28-38 Nm (38-52 lb-ft).
Add Motorcraft Rear Axle Lubricant XY-90-QL or KL (ESP-M2C154-A) or equivalent until it is 6-14mm (1/4-9/16 inch) below bottom of fill hole. Add 118.3 mL (4 oz) of Ford Additive Friction Modifier C8AZ-19B546-A (EST-M2C118-A) or equivalent to Traction-Lok axles. Install fill plug and tighten to 20-41 Nm (15-30 lb-ft).
Insert Rear Bearing Remover T85L-1225-AH in bore and position it behind bearing so tangs on tool engage bearing outer race. Remove rear wheel bearing and inner wheel bearing oil seal as a unit, using Impact Slide Hammer T50T-100-A.
Rear Disc Brake Caliper Anchor Plate
Lubricate the rear wheel bearing with Rear Axle Lubricant.
Install rear wheel bearing into the housing bore using Axle Tube Bearing Replacer T78P-1225-A.
CAUTION: Installation of rear wheel bearing or inner wheel bearing oil seal assembly without proper tool may result in an early bearing or seal failure. If inner wheel bearing oil seal becomes cocked in bore during installation, remove it and install a new one.
Install the inner wheel bearing oil seal using Axle Tube Seal Replacer T78P-1177-A. Use Premium Long-Life Grease XG-1-C or K (ESA-M1C75-B) or equivalent between the lips of the inner wheel bearing oil seal .
The large bolt that you see is the nut that holds the axle shaft to the hub. You do not need to remove it to remove the rotors. You just need to remove the caliper & the caliper bracket. Normally, the rotors come off of the hubs easily, but sometimes, they rust onto the hub. My techs beat and beat and beat until they come off. With large hammers. Note that after they are beaten off, the rotors are no longer viable for re-use.
