Question about NEC-Mitsubishi MultiSync LCD1770VX (Black) 17" LCD Monitor
Transistor nb 27611 what it is? - NEC-Mitsubishi MultiSync LCD1770VX (Black) 17" LCD Monitor
    Problem Solver:
  • 16 Answers
This is a MOSFET not a transistor, 2761I, not 27611
http://www.alldatasheet.net/view.jsp?Searchword=AP27611
Good luck
Posted on Jun 13, 2010
  • s pot lite Sep 17, 2011
    What do you think the T in MOSFET stands for Prof.?
SOURCE:
What is the function of transistor number 27611 in a monitor
Regulate the voltage to the monitor or to the power supply for the monitor
Jul 05, 2016 | HP Computers & Internet
Tip
Digital camera battery, camcorder battery and charger online store -...
Laptop batteries, like all rechargeable battery packs, lose their charging capacity over time. Because new Laptop batteries are expensive, replacing the individual cells inside the battery casing can save a lot of money. However, rebuilding a battery sometimes does not work as expected, so it’s important to be willing to purchase a new laptop battery if the procedure fails.
90-04208-003_original-hp-pavilion-dv8000z.jpg?w=250
HP Pavilion DV1100 Battery 12 cells
1、Allow the laptop battery to run down completely. Turn off your laptop, then remove the battery. Write down the model number located on your battery to help identify the type of Li-ion replacement cells you need to purchase.
2、Split open a small section of the laptop battery pack (at the seam) with a screwdriver or craft knife. Continue to pry the plastic case loose moving around the outer edge until the entire top is free. This may take a bit of force.
3、Note the number of cells inside the case (usually four to eight). Write down the part number and voltage information printed on the cell casings. Draw a diagram showing the arrangement of the cells and how they are connected, or take a few photos to help with reassembly.
4、Purchase the correct number and type replacement batteries from online shop such as udtek.com, based on your battery model and cell specifications. Six Li-ion cells typically cost around $30 to $40.
5、Carefully remove each cell using a craft knife and wire cutters as necessary. Each battery pack is different, but the cells are usually wrapped in a plastic casing with metal contacts attached to one end. Lay the metal contacts, wires and casing material aside.
6、Use double-sided tape or a solder gun (only if necessary) to attach the metal contacts to the cells and circuit board. When finished, the old cells should be completely stripped (naked) and the new cells should look like the old ones as much as possible.
7、Place the new cells inside the case, referring to your diagram or photos if necessary. Glue the battery(Compaq DV6000 Battery) pack top back on. Charge the new battery for at least 24 hours before using it.
Tips & Warnings
Keep an eye on the new battery while it charges for the first time. If the contacts are not connected properly, the battery could overheat and cause damage to the laptop.
on Oct 21, 2010 | Computers & Internet
What causes the horizontal transistor to short? flybak ok, supply line ok. my tv is a samsung with a model #: ct-21k30mh.
Hello
You just replace the capacitor fitted very near to the horizontal output transistor,[freewheeling capacitor], there may be one or two of them, whcih comes to a value of 3900pf to 6700pf 2000V or so. It is connected to the negative rail and the collector of the horizontal output transitor. If it gets opened, or its value gets reduced, this fault will occur. If so the transistor you replace will get shorted as you swich on the power to TV.
The second one is deflection yoke short. If so the transistor said above will overheat within seconds. Even a single winding inside the horizontal deflection yoke shors, it puts a tremendous load to flyback transformer, which in turn effects the transistor.
After replacing the above said capacitor, you do one thing to make sure about whether there is a short inside the yoke or not. It cannot be measured by normal methods. Fore that, unplug the base card from picture tube and place it somewhere near without getting any of its contacts to other parts inside your TV. This time only the EHT chord will be connected to picture tube. Unplug the horizontal yoke connection from main board. Switch on the tv, and wait for some time, say at about 10 seconds, and check whether the transistor gets overheated or not If it does overheats now also, the winding or EHT retifier diodes inside your flyback transformer has some trouble, and it should be replaced with same type and number. If it does not overheats now, the deflection yoke's winding have some short in it. Ok.
NB: Never connect the TV with base card is in postion while deflection yoke connection is isolated. keep it unpluged.
Oct 27, 2010 | Samsung Ultra SlimFit 20" Digital TV
Makita 1850 battery charger FIX. A friend asked me to check his charger unit which had failed after it had been connected to a portable petrol generator that incorrectly generated 317 Volts AC and not the...
I have a BL1830 Lithium Ion LXT battery that will not charge because the charger tells me the battery is broken. I have taken the battery apart to find no problems with the connection from cell to cell. There is a small circuit board that I cant find any visible signs of damage on. The battery will still run a flashlight or a drill but it is almost drained.
May 16, 2010 | Makita Drills
Part no. for a Transistor 27611 637205
I was looking for the same part and discovered that it is an AP2761I (capital i not one at the end). Documentation on it can be found at http://doc.chipfind.ru/a-power/ap2761ia.htm.
I haven't yet found a supplier as, in this Dell E153FPf 15" LCD monitor, neighbouring components R856, C856 and R861 are so burnt out that I don't know what values to replace them with. If in return you could tell me the values of components near your AP2761i-A, I would appreciate it.
Mar 28, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Fit my Canon NB-4L Battery
Canon nb-4l battery pack canon 100 percent compatible with you canon nb-4l camera battery. I bought two canon nb-4l battery from http://www.camera-battery.co.uk/canon/nb-4l.htm two weeks ago, I felt very surprised, because it fits nearly as good as the original battery.
Feb 06, 2009 | Canon Cameras
Lost charger
No you can't. Recommend just buying another charger. Generic NB-4L chargers are relatively inexpensive ($6 to $10). So are the generic NB-4L batteries. Here's some chargers from Amazon:
http://www.amazon.com/s/ref=sr_st?keywords=canon+nb-4l+charger&rs=172282&page=1&rh=n%3A172282%2Ck%3Acanon+nb-4l+charger&sort=price
Feb 16, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Infrared bulbs Panasonic NB-G100P
Many parts are available from Panasonic's website for this model. Do a search for NB-G100P then click the displayed link. from that page, you should see a link at the bottom of the page for parts.
http://www2.panasonic.com/consumer-electronics/support/Home-Appliances/Kitchen-Appliances/Toaster-Ovens/model.NB-G100P
Stan
Nov 04, 2007 | Panasonic NB-G100P 1300 Watts Toaster Oven...
Open Questions:
See all NEC-Mitsubishi MultiSync LCD1770VX (Black) 17" LCD Questions
NEC-Mitsubishi MultiSync LCD1770VX (Black) 17" LCD Monitor Logo
1,360 people viewed this question
Top NEC-Mitsubishi Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
Ehsan
Level 1 Expert
Joaquim Martins
Are you a NEC-Mitsubishi Computer and Internet Expert? Answer questions, earn points and help others
