SOURCE: Only see a blue screen ...
Hi, The bluescreen is an indicator of "lack or absence of a video signal". In TV mode this would only come on if your reception quality is so poor that the TV "thinks" there is more interference/noise than intelligent video signal nd therefore mutes the video. In all other modes, (S Video, A/V Video etc), again, this muting action will result in the bluescreen if the TV "thinks" it is not receiving any video input. To try and fix this would either be: 1. Check and verify that you have a video signal coming into the TV by trying your video source (DVD, cable box) into another TV unit; or 2. Check and verify that your connectors at the back of the TV and the source are properly connected and are snug/fitted properly. If both fails, it is possible that you have component failure inside the TV and that would require the services of a qualified TV professional. Hope this be of help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
SOURCE: FLM 3232 PROBLEM
the control board is out on all of your tv's very common problem the board new was 479.00 . part no 909 KSO GF321XA, do a internet search, you will see i am right, if interested i have one good used and i will accept offers, its easy to install would take 30 minutes with four screws and five wire harness plug ins. can do your self.
SOURCE: No Signal - Input w/ Cable does not work
I have same problem with my polaroid LCD tv.... Im thinkin about renting a gun and buying a bullet to fix it :D
SOURCE: 37" Polaroid LCD TV No signal appears when select channel
I was having same problem, and think I got lucky and found fix.
Try unplugging the TV and waiting 30 seconds, then plug back in.
You will likely get blue screen with "No Signal".
Go to Menu, then scroll down to "Setup". Select "Factory Reset" then hit "Yes."
This did it for me. Wish you all luck.
SOURCE: no signal and blue screen
hello
i think you might have a blue screen of death on your tv
--full str pka
