Go to Start, control panel, Sound and double left click on Sound. When that opens up it should show a list of your sound devices and which is is set to be the default playback device. You can also change recording and playback volumes here or unmute. Depending which device is set as default the media player should playback on that device.
Hi, Please open the link below and follow the instructions there to resolve the issue if the problem persist after following the instructions then pen drive is defective.
Can i suggest you try the following : Go to 'start', 'run',then type 'cmd', enter (if using vista, start, all programs, Command promt) type in format x: (x: refering to the drive letter that your usb device is assigned to), then hit enter. It should give you a warning about erasing all data, etc.
When i turn on of my pc. then bios screen msg reboot and select proper boot device or insert boot media in the selected boot device. How to solve of this problem. pls .............solve tips for give me.
sEVERAL POSSIBILITIES:
* You downloaded protected music on your Windows 98/98SE, Windows 2000, Windows XP computer using Windows Media Player 9. Music was purchased online or the music was ripped form your own audio CD with Copyright Protection turned ON. o You must use Windows XP and Windows Media Player 10 for online purchased songs. o You must turn OFF Copy Protection on your Windows Media Player 9 before ripping your audio CDs into WMA files * You downloaded protected music to your MP3 player using your Windows XP computer and Windows Media Player 10 with your player in USB mode. Music was downloaded from the internet, purchased or subscribed, or it was ripped from your own audio CD with Copyright protection turned ON. o You have to use your MW3836 in MTP mode.
-Tha Mp3 Doctor
if u format ur pen drive. then use this step -
Check out the registry under:
1)click on start button 2)clik on run dialog box 3)type regedit 4) HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
The value 'WriteProtect' should be absent or set to '0' and when you try to format it you have to format it as FAT16
do you know its a problem occur when device ejected harshly try to plug it may solve your problem or try this go to my computer> properties>hardware > device
manager >universal bus driver>right click on it> update
driver> then1 1.yes this time only> next2.choose advanced option>next3don't search i"ll update from........>next4.click on show campatible> next> next5. now it updated then restart you computer your problem will now soved
