Hello
I've just installed the roxio creater 6 disc and would like to copy a DVD onto a disc from my hard drive. However, the 'drag to disc' feature (mentioned in the tutorial as the way to do this) is not there! There's just a space where it should be on the list of icons... Any ideas? Thank you in advance!
SOURCE: roxio
check out roxio's support forums. they're helpful. http://www.roxio.com/eng/support/default.html?source=rgbuzz
SOURCE: Adding data file to existing CD-RW disc in Roxio
First off, for your information your Roxio is OLD, they now have Roxio 9.
But that will not solve your problem. Can you open the CD and copy and paste anything? Or is the CD "Read Only"? If read only, it is because when you "Finalized" the CD you optioned the "Write Protect" making writing to the disk impossible. This protects the disk from erasure too.
You will need to use another disk.
Otherwise you can just use the same method you used before to write to the disk, or Copy and Paste, or Drag and Drop.
The Write Protect is specific to the program you are running.
However, Roxio 7 and 9 program I have used ask, "Do you want to be able to write to this disk again?" or words to that effect. All you need to do is just put a check in the box (or not, if you want to write to disk again). This happens when you are ready to remove the CD or DVD from the drive. Then the program runs a "Finalizing" program before the disk automatically ejects.
SOURCE: Cannot Initialize API
1. Try to launch Creator Classic to see if it can repair the engine files. a. Double click on the "Roxio Easy Media Creator Home" icon. b. Click "Creator Classic" under the "Applications" section. c. The Windows installer should launch and ask you to insert your installation disc
Try this and see how it works, if it does not, contact me and give me more details
SOURCE: Canon Roxio MyDVD download difficulties
I don't think version 6 is going to work in Vista.
Here is the bad news from Roxio directly on it
Only versions 9 and higher will be supported for Vista.
SOURCE: roxio creater wont download
you just have to reinstall it if it happens again get a new copythe installer might be corrupted
