Black & Decker Distance Measurer with Sensor, Marksman Logo
Posted on Mar 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello, I want to calibrate a Marksman Distance Measure, but I dont know how I have to. Please, help me. thanks in advance
Dana Newcombe
Level 3:
President:
  • Master 1,564 Answers
  • Posted on Mar 05, 2010
Dana Newcombe
Master
Level 3:
President:
Answers
1564
Questions
Helped
540425
Points
4667
If you take a tape measure and step from the wall at exactly 10 feet, you will be able to turn the calibration knob to the same exact distance. All other distances from that point on will be precise. Thank you, Dana
1helpful
Echo ecr2 reading wrong distance and speed. have lost manual
It must be re-calibrated to match the outter circumference of the tire. Sit on the bike and measure how far the wheel rolls on one revolution, exactly. Multiply the inches of the circumference by 2.54. This converts the inches into mm and that is the number you use to calibrate the cyclo-computor's basic need. You can probably find the user's manual on the web. Save and keep ALL your instructions in a shoe box or folder. OK?
Dec 31, 2014 • Cycling
Does not measure distance
Put in new batteries, clean lens, and calibrate. If this does not work, type " Leica Disto A6 Laser Distance Meter user manual " into computer search engine. It will bring up sites for manual.
How to use stud finder
While holding the stud finder on a spot on the wall where you assume there is no stud... press the button and hold and stay still for 10 or 15 seconds to calibrate. Then while still pressing the button start sliding sideways until the lights indicate the thickest point. You can use a pencil to mark the beginning and end. The center of that is the center of the stud. Measure 3/4 of an inch left and right of it to know it's sides.
How do you set the distance to miles
Dear Sir:
Hello, I hope everything is fine.
I will help you inmediately.
Things You'll Need
  • Pencil
1.
    • 1
Switchthe power off without unplugging the machine. Do not take the safety key out ofits place.
    • 2
Inspectthe bottom of your console. The calibration switch is in a small hole. Insertthe eraser end of a pencil into the hole and softly push the button. You willsee CL11 on your console after you push this button.
    • 3
Usethe Speed + or - key to select MPH or KPH. Push the Power key to save yourselection.
Thank you in advance, sincerely. God bless you
If you need further assistance, please reach me.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
1helpful
My marksman never gives anything but an E reading
mine does that when battery is low or red light not bouncing back
I got a Vetta rt55 dont know the tire setting. My tire is 27x1 1/4. Thanks
measure the outer diameter of the tyre.put a mark on the side of the tyre and put to the floor.this will be a starting point to measure the tyre.get a tape measure.now roll the wheel foward and do one full rotation until the mark comes back to the floor.now measure that distance between from where mark started and finished. eg if you measured 2 metres then enter 200cm or 2000mm.most speedos usually except measuments in mm though.hope this helps
Oct 13, 2010 • Cycling
Angle
The maximum is -20 degrees to +20 degrees. (pg. 9-para.2 of the manual)
mtg
Top Black & Decker Measuring Tools & Sensors Experts
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Are you a Black & Decker Measuring Tool and Sensor Expert? Answer questions, earn points and help others
