ck for a fuse in the under the hood fuse box that says bsm may be blown.
Also try this.....
To reset the security system remove the negative battery cable for 30 minutes, then reconnect the cable. Next, lock and unlock the doors using the remote. This will reset the alarm system and the engine will start and fobs reset.
Here are some factory notes....FYI
Anti-Theft Systems
PROGRAMMING
NOTE: If a new Smart Entrance Control Module (SECU) is installed, a new identity code must be entered and all remote controllers must be programmed. If identity code cannot be entered, repair multi-remote system. See appropriate MULTI-REMOTE CONTROL SYSTEMS article.
PROGRAMMING > PROGRAMING NEW ID CODE
NOTE: This procedure will erase all previous identity codes and render all previously programmed remote controllers inoperative (until reprogrammed). All remote controllers to be used with system must be programmed at the same time. A maximum of 4 remote controllers can be programmed. Any attempt to program more than 4 controllers will be ignored. If same identity code is entered more than once, entry is ignored even though hazard warning lights will still flash twice.
1. Close and lock all doors. Erase original identity code(s) by inserting and completely removing key from ignition switch more than 6 times within 10 seconds. Hazard warning lights should flash twice. Turn ignition switch to ACC position.
2. Push any button on new remote controller once. Hazard warning lights should flash twice, indicating identity code has been entered. If identity code cannot be entered, repair multi-remote system. See appropriate MULTI-REMOTE CONTROL SYSTEMS article.
3. For each additional remote controller to be programmed, manually release door lock and lock again by using door panel switch and repeat step 2. If no additional remote controllers are to be used, exit programming mode by unlocking and opening driver's door.
Please let me know if you need anything else to get the problem fixed. Happy mew Year!
Why not just get the factory PATS System working correctly. You can't remove the factory system,it's an integral part of you vehicles systems and processors
Your vehicle has a anti-theft system in the keys/column. It is activated when you take the key out of the ignition. The theft light on the dash should blink.
Hello thank you for choosing FixYa.com for your answer my name is David.
I have found a list of codes for the rcu600m for the sylvania tv here they are Code For Model RCU600M
Code 004 for Sylvania TV
Code 006 for Sylvania TV
Code 008 for Sylvania TV
Code 019 for Sylvania TV
Code 062 for Sylvania TV
Code 068 for Sylvania TV
Code 069 for Sylvania TV
Code 075 for Sylvania TV
Code 076 for Sylvania TV
Code 077 for Sylvania TV
Code 088 for Sylvania TV
Code 116 for Sylvania TV
Code 130 for Sylvania TV
Code 132 for Sylvania TV
Code 134 for Sylvania TV
Code 161 for Sylvania TV
Code 183 for Sylvania TV
Code 196 for Sylvania TV
Code 353 for Sylvania TV
Thank you again for choosing Fixya.com
Hello, if you have your original remote you can program your remote to learn the button from the original (if your universal remote has that function) if not the then you will not be able to. Check for your manual here: Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC3110
just right click and save as on the download links.
