Hi Alan, Please ensure that the printer driver is set correctly. Go to your Printer & Faxes menu, right click the C250, click printing preferences, click the Quality tab and make sure Colour is selected. Apply the changes and bingo! The above assumes you are using Windows and a PCL driver. Hope it helps
www.fixya.com > Forum > Printers & Copiers > Konica Minolta
Konica Minolta BizHub C252 - pale colors on the long side · Konica Minolta. ... I have a Konica C250 machine which cannot print red color at all. I had changed ...
www.fixyourownprinter.com/posts/40820
Aug 22, 2008 - On the right hand side of the drum (the part that has the large green handle) that easily slides out. There is a ..... I have konica minolta bizhub c252 colour printer. ... The K light came on a long time ago and is constant on now.
? 0:28
https://www.youtube.com/watch?v=eD8HdNq0MlE
Nov 23, 2011 - Uploaded by Tennants Nottingham
How to clean the drums/i units on the konica minolta number plate printer ... Fix or repair color laser printer with fading, lightprint, or lines samsung clp 300 ... Imaging Unit Reset for Konica Minolta Bizhub C203 / C253 / C353
Does the demo page do the same? Mite have image control board failure. And electrical storms on a good surge protector not a Ace hardware 19.99 special, of course nothing against Ace Hardware :). Could also be a High Voltage board failure. Meter count page OK print out.
First, I should ask where you buy your toner and what quality is it. If it's not a genuine Konica Minolta toner you will run into more problems.
Your first check, print using about 5 copies of card, if the prints on the cards shows shadowy image or you find shadow repetition of the prints, that's a confirmation of a bad toner quality.
Fusing unit life is over or it can be the paper size problem.if you are using manual by pass tray for A3 printing then make sure machine is detecting A3 in manual by pass tray.if its OK then problem is in fusing unit.
YES,
you can use either the User Authentication or Account Track. With authentication you can give public access to BW and require a password for colour. With Account Track you can create users and limt acees, but you CANNOT give public access. ALL users would required to have a code. This is controlled for copy, scan and print functions.
any stripes are usually caused by imagining unit, first use the tool in front cover to clean laser glasses. inspect IU drums for stripes maybe youll need to change them. is the page coming out ok, but picture is printed crookedly ?
