My HP officejet D145 come up with scanner failure message and cannot print or copy anything since last week.
Please reply ASAP. Otherwise I have to order new in order to get my work going.
Thanks
Navangi
Scanner Failure, Power Off and On' Message Displays on the Control Panel when Copying or Scanning
Issue
The message 'Scanner failure, Power off and on' displays on the control panel of the product.
This error usually occurs when trying to scan, to make copies, or during the product start up.
Try the solutions in this document until the issue is resolved. It is not necessary to continue to the next solution if one solution resolves the issue.
Solution one: Check the scanner light
Make a color copy of any document by pressing the Start Copy Color button on the control panel. While the product is making the copy, slightly lift the scanner lid to see if the scanner light is visible.
CAUTION: Do not look directly at the light. It is not necessary to completely open the lid to see the light.
If the scanner mechanism moves across the scan bed, but the light is not lit, click here to service the product .
Solution two: Check operating conditions
Extreme temperatures can affect the operation of the product. Make sure the operating conditions match those recommended in the User Guide provided with the product.
Solution three: Check the power connections
1.
Make sure that the product is connected directly to a grounded wall outlet and not plugged into a power strip.
2.
Make a color copy by pressing the Start Copy Color button on the control panel.
3.
If the error message persists, temporarily move the product to a different room or outlet, and then make a color copy by pressing the Start Copy Color button on the control panel.
4.
Check the part number on the power supply to make sure that it matches the part number listed in the User Guide.
Solution four: Perform a power cycle
1.
Turn the product off.
2.
Unplug the power cord from the product.
3.
Wait 30 seconds, and then reconnect the power cord to the product.
4.
Turn the product on.
5.
Solution five: Reset the product
Follow these steps to reset the product.
Step one: Perform a partial reset
1.
2.
Press and hold # and 3 while plugging in the power cord.
3. Make a color copy of any document by pressing the Start Copy Color button on the control panel.
If the partial reset resolves the issue, do not continue to the semi-full reset.
Step two: Perform a semi-full reset
CAUTION: Performing a semi-full reset deletes any phone numbers that are saved on the product.
1.
2.
Press and hold # and 6 while plugging in the power cord.
Solution six: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
message is "Scanner failure. Turn power off then on again." Turning off then on again does not solve the problem
Scanner failure and I have re-installed many times. This week I cannot print or copy.
scanner failure message ,unable to receive or send faxes. I unpluges the power source and repluged it again. It seems to work, however the problem keeps on reaccuring!
How do you get the scanner assembly open to clean mirrors?
I also get the "Scanner Failure" message with instructions to turn off and then turn on again. It happens whether the computer is on or off, beginning shortlyafter turning on the computer. Generally, after repeating the procedure, the problem will recur intermittently, for a total of three times, and then stops happening for the rest of the day. Other functions seem to be working okay, although veerrrrry slooow to warm up before first copy. I so rarely use the fax component that I really don't know whether it is working or not; no trouble light comes on as it does with the scanner failure.
