Culligan Sediment Water Filter Logo
Posted on Mar 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Culligan 01010091 (mark 89) softener will not auto
Culligan 01010091 (mark 89) Aqua-sensor softener will not auto or manually regen - water runs out discharge drain continuously when manually tripped
Anonymous
Level 3:
  • Master 10,319 Answers
  • Posted on Mar 06, 2010
Anonymous
Master
Level 3:
Answers
10319
Questions
5
Helped
3074919
Points
30576
Clean the drainage filter then it will work correctly again
Culligan water softener mark 89 model 3526-82,3526-83. unit doesn't seem to be drawing brine during regeneration
Either the electric valve has failed, or the line is plugged. Try blowing out the water line first and free it up from buildup and then if it seems unobstructed, check the valve function. Salt crystal buildup is common.
What causes culligan water softener tank to mak noise
The noise is normal during regeneration and draining.
You can manually set the regen clock to a different time.
There are Noises in My Culligan Water Softener Regeneration System Hunker
2helpful
Need a manual for a culligan mark 89 water softener, It's not a digital, it's a dial type settings.
Here is a the link for the MK 89 Use and Care Guide
http://www.isingsculligan.com/manuals/Mark89-812%287-97%2900881597.pdf
If you are looking for a parts manual that may be almost impossible as they are very protected.
RJ
How do I perform a manual regeneration to test my Culligan water softener (medalist series)? The owner's manual does not explain how to do this. On the digital display for the unit, the word REGEN...
Hold the REGEN button down for 5 seconds. This initiates a manual regeneration. You can step the unit through the cycles by pressing the UP arrow.
RJ
2helpful
How do i manually renerate culligan wg 844
To manually regenerate at 2am push regen button once. To regen immediately push regen button 2 times.
RJ
4helpful
Culligan Estate 2 Model 01010091. Back wash will not stop.
The back flow filter is clogged. It will need to be cleaned out. When it is clogged the pressure reverses so the valves will stay open to clean without shutting off
Regeneration is nightly as oppsoed to the prrprogrammed 14 days
"DAYS00" indicates it is set to run every day. You may have lost power and it reset to factory settings. If the Gold series softener you have is the Aqua Sensor model (this is a probe in the resin tank that senses a change in the water chemistry and sends a signal to regenerate) the probe can get coated with iron and will either send NO signal or a Constant signal which will make it regen every night.
Usually a Gold series softener is either set up as metered or aqua sensor. There is an option for an override (such as 14 days) or it can be set up as a time clock model. Unplug the softener for 2 minutes and plug back in, re-program the controls to "DAY14". Make sure what the system is suppose to be set up as, Meter, AS, Time Clock.
Here is a link to Culligan for the Gold manual.
http://www.culligan.com/en/service-and-maintenance/customer-support/owners-guide/
RJ
2answers
I have had salt in for 3 weeks culligan mark 89 is not recharging
If the unit will recharge then you might have what is called a salt bridge in the tank. The salt is stuck above the water level in the salt tank. Poor a gallon of water over the top of the salt and see if you can then break it up. The salt should go down then.
2answers
No salt leaving Culligan softener during regen
I have the same problem... did you find out what was wrong???
Top Culligan Measuring Tools & Sensors Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Culligan Measuring Tool and Sensor Expert? Answer questions, earn points and help others
