I have a Kitchen-aid electric range/oven. Model #YKERC507HW4 and button #2, #4, and "timer set/start" buttons stopped working. Any ideas on what may be the problem?
This may sound facetious, so don't get offended.
Did you set your clock to the correct time?
Did you clear any and all preset timers?
If none of that helps you can usually find roaches in the strangest places. If you have no roaches, then moisture and heat are the likely culprits which means that your blister pads are simply worn out. Unfortunately these are coated with graphite and don't last forever, so a timer replacement would be your only option unless your touchpad is separate from your timer.
