Want manual gprs setting for spice, vodafone, bsnl for
Want maual gprs setting for spice, vodafone, bsnl for htc s710 model .because gprs setting send by operator was not going to install automatically . location : chandigarh, india
and clice right button and select add write down below setting with respective .
Account Name – Hutch_GPRS User Name – Blank Password – Blank Proxy – Enabled/yes Access Point Name – portalnmms Full Internet Access Point Name – www Proxy and Server address – 10.10.1.100 Proxy and Server Port – 8080 Homepage – http://hutchworld.co.in Authentication Type – Normal
Manual Airtel Gprs Settings Homepage – any page you want to set. User Name – Blank Password – Blank Proxy – Enabled/yes. Proxy and Server Adress – 202.56.231.117 Proxy and Server Port – 8080 Data bearer – GPRS or Packet Data. Access Point Name – airtelgprs.com Authentication Type – Normal Use preferred access point – No
Manual Airtel live settings Account Name – Airtel_live Homepage – http://live.airtelworld.com Username – Blank Password – Blank Proxy – Enabled/yes Proxy and Server Adress – 100.1.200.99 Accespoint Name – airtelfun.com Proxy and Server Port – 8080 Data bearer – GPRS/ Packet Data Authentication Type – Normal
Manual Idea Gprs Settings Account Name – idea_GPRS Username – Blank Password – Blank Homepage – http://wap.ideafresh.com Proxy and Server Port – 8080 Proxy and Server adress – 10.4.42.45 Databearer – GPRS / Packetdata Acces Point Name – imis Proxy – Enabled/yes Authentication Type – Normal
Manual Bsnl Gprs Settings Account Name – BPL WAP Username – Password – Proxy – Enabled/yes Homepage – http://wap.mizone.bplmobile.com Proxy and Server address – 10.0.0.10 Proxy and Server Port – 8080 Acces Point Name – mizone Data bearer – GPRS/ Packetdata Authentication Type – Norm
tata docom Data Bearer: GPRS Access Point Name: TATA.DOCOMO.INTERNET Connection Security: Off Session Mode: Permanent
now again click on start>internet explore>right button menu> tool>option>connections>remove automatic detection setting and below this chose internet..click on start>setting>connection>gprs
Manual Bsnl Gprs Settings Account Name – BPL WAP Username – <Blank> Password – <Blank> Proxy – Enabled/yes Homepage – http://wap.mizone.bplmobile.com Proxy and Server address – 10.0.0.10 Proxy and Server Port – 8080 Acces Point Name – mizone Data bearer – GPRS/ Packetdata Authentication Type – Norm
Reliance GSM GPRS Free Manual settings >Reliance Manual & Free GPRS settings >For Gsm APN-> rcomwap Proxy-> 10.239.221.5 Port-> 8080 HomePage-> www.google.com
After entering respecting setting .click ok
You can't post conmments that contain an email address.
i am elamurugu. i connect the htc mobile with bsnl cellone GPRS as following method. ies
go to start
go to setting
go to connections
in this go to connections
go to gprs setting
go to Add a new modem connection
go to General Enter a name for these setting as: BSNLGPRS Setting
Select a modem as :CELLULAR LINE (GPRS)
Next
Access point name: GPRSSOUTH.CELLONE.IN [as i am tamilnadu bsnl south zone]
Next
User name: YOUR CELLONE NO 94**********
Password: YOUR CELLONE NO 94**********
Finish
go to Proxy setting
select [tick] This network connects to internet
select [tick] This network uses a proxy server to connect to the Internet
then go to Connection Setup
Select Operator
Country: India
Operator : BSNL
then OK
Do you want to continue?
Yes
finally RESTART YOUR DIVCE
say YES.
Afer restart you can now use bsnl gprs.You have note a symbol at top of your htc mobile as E or G.
If you have problem to connect bsnlgprs With this correct setting call cellone customer care about this or call me
hi jigo123p, Vodafone will not be able to send you the setting via sms. You will have to call 111 or 9825098250 and ask them to tell you the settings and you will have to enetr them manually on your phone,
On your phone go to start> settings> connections> connections> add a new modem connection> Name = Vodafone gprs> modem type = Cellular line (gprs)> Next> Now enter the settings that vodafone customer care people gave you, manually
After browsing a lot of sites and experimenting with the settings finally I was able to configure my HTC P3400i with Vodafone Live support without any help from the Vodafone customer care (who were very bad and rude when I called them for getting the setting). The settings is working fine for me in Bangalore. Hope this helps all who bought this phone and struggling for getting the GPRS setting for HTC P3400i.
Below is the step by step instruction: Step 1 Start->Settings->Connections->Tasks->Add a new modem connection:
Enter a name for the connection: <give any name>
Select a modem: Cellular Line(GPRS)
click next
Acess point name: portalnmms
User name: <blank> Password: <blank> Domain:* <blank>
Go to Advanced->TCP/IP select radio button "Use server-assigned IP address"
Go to Advanced->Servers select radio buttion "Use server-assigned address"
Step3: Start->Settings->Connections->Advanced In "Select which networks are automatically used"-> click the Select Networks Programs that automatically connect to the Internet should connect using: Select the Connection name which you configured in Step 1
Programs that automatically connect to a private network should connect using: Select the Connection name which you configured in Step 1
hi prasath i am using the same handset just let me know is ur handset is properly app unlocked and one more thing that error is about ur gprs settings .Currently i am using Vodafone Gprs and i have manually configured gprs settings .if u wamt more info just send me an email me at [email protected] and use opera mini instead of winwap it works great on dash
User Name – Blank
Password – Blank
Proxy – Enabled/yes
User Name – Blank
Password – Blank
Username – Blank
Password – Blank
Proxy – Enabled/yes
Username – Blank
Password – Blank
Proxy – Enabled/yes
Username –
Password –
Proxy – Enabled/yes
tata docom
Data Bearer: GPRS
>For Gsm
APN-> rcomwap
Port-> 8080
