SOURCE: Can I install the print master platinum 16 on my
yes. You can. If your printer manufacturer provides the driver. So goto the web site of your printer manufacturer and specify your printer model and select operating system as Windows 7. If the driver is available, there you go. :)
Please come back and vote for me if this turns to be helpful for you or also if you need more clarifications.
Thnx
SOURCE: Broderbund Print Master Platinum 16 is not
Not compatible or not working well with windows 7?
Maybe, It doesn't work because the driver/application you installed is
for other versions of operating system. I am also using windows 7 like
you so don't you worry, You can still use your old installer/driver from
other versions of operating systems. Just remember that before
installing any program in a windows 7 Operating System Computer, Use
"troubleshoot compatibility". Right Click the Icon of your program
installer/application first, then choose "troubleshoot compatibility".
This will allow you to choose on what type operating system your program
will run. Just reply back if it still doesn't work.:D rate and vote
for me:))
