Question about Bunn NHB Coffee Maker
I have had my Bunn since 1999 and I have had no trouble whatsoever until today, it decided to become a steam roller and will not shut off at the reserve hot water well. I have to power off the switch each time I make a pot of coffee as the coffee making process still works.
    Scholar:
  • 40 Answers
It is most likely time to decalcify the machine. If you haven't made a regular practice of this, a cocoon of mineral deposits has encased the heating element causing it to struggle to warm the water adequately even as it overheats itself. If one or more decalcifications using white vinegar and the instructions in your owner's guide fail to improve the situation, the thermostat may be faulty. Contact BUNN for toll-free support:
https://www.bunnomatic.com/retail/service/contact.html
Posted on Mar 05, 2010
SOURCE:
How to stop a steam iron from spitting and spluttering from out of the filling hole with its lid shut.
if you have had enough of the problem junk it and get a new one
it will not be cost effective to repair any way
Jun 15, 2016 | Irons
Why is my 99 dodge intrepid steaming after warm up then cuts off til cool
Which engine, 2.7L?? Is it full of coolant?? If the water pump has failed, it a pretty expensive repair.
Aug 10, 2014 | 1999 Dodge Intrepid
Won't shut off after making a cup
It sounds like the thermostat or Element is failing and causing your unit to overheat and boil. Probably time to call Bunn and see if your unit is under warrenty.
May 03, 2014 | Bunn My Cafe MCP
Boiler will not cycle, w/not shut off
@charlie
Maybe this will help you, with information, trouble shooting and contact numbers.
BUNN VPS COFFEE MACHINE MANUAL
http://www.bunn.com/pdfs/commercial/manuals/10053.0000.pdf
Also if you could rate this and some kind words would be great. Also here is my direct link to my pages of expertize that might help you. Visit me anytime at :
http://beta.fixya.com/users/mc1bean
Thanks So Much, Mike
Jul 22, 2011 | Bunn VPR Coffee Maker
Have had my Bunn Home Coffee Maker for 2 years and it's worked like a charm! Unfortunately it has decided to go retire with no warning whatsoever :-( It just out of nowhere stopped working all...
Tools needed to dignose
An screw driver and an AC electric tester.
STEPS
open the pannel and chek the voltake is comming into the machine first.
reply me after that
thanks
Feb 09, 2011 | Bunn 10 Cup Home Coffee Brewer
Bunn vpr steams everything out fill hole and nothing comes through copper tube, even after cleaning tube and head.
Fill water tank until water comes out from sprayhead, THEN plug it in it should be OK.
IF the machine keeps blowing steam/keeps boiling the water, The thermostat is defective and must be replaced.
NOTE: If you don't use the machine for a couple days, UNPLUG IT. The water will evaporate if you don't unplug it.
Jan 13, 2011 | Bunn VPR Coffee Maker
I bought my steam mop in February 2009 and had no trouble with it until today when it would not put out steam. It made a gurgling sound, but emitted no steam.
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Nov 11, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Neon won't start
It's the starter i had the same problem once with a car and i had to replace the starter
Oct 19, 2008 | 1999 Plymouth Neon
Bunn NHB Coffee Maker Logo
170 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Inky Fingers
Inky Fingers
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
