Janome ENX24. needle tension will not adjust
Set the tension to zero and floss it with a piece of fabric or twill tape.
Re-set the tension to 4, or where you would normally set it for this machne.
Thread the machine with the presser foot up, this opens the tension contol to allow the thread to enter.
If you are still having a problem, the machine needs to go in for service.
There is an adjustment on the side of the black bobbin case.
Remove the needle plate, to gain access to the case. Lift it out, noting how it is positioned! On the side of it , there are two screws, one is the adjustment screw - its the one that sits out more. To increase tension, turn it clockwise 1/8th of a turn, reassemble and test sew. (make sure the top thread tension is back to where it should be). Repeat if required. DO NOT adjust too much at a time!
Good luck
Tension wheel moves but will not adjust the stitch
The tension moves but will not adjust the stitch or the tension is locked up and you cannot move it?
