ViewSonic PJ551 Multimedia Projector Logo
Chuck Walek Posted on Mar 04, 2010
Ceiling mounted PJ551 - lamp light red, power light blinks red
Ceiling mounted PJ551 - was working, now when it turns on, lamp light goes steady red, power light blinks red.
Bought new bulb, same problem. Cannot get any image, since bulb won't light, so can't go to menu.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 12, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1610
Points
I have PJ 550 exact SAME PROBLEM replaced bulb NOTHING
Green and yellow color with viewsonic pj551 projector
the LCD panels are failing
the price is USD100
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
2helpful
2answers
I can't get my Vivitek projector a d952hd model to show light anymore - it is only 6 months old and I doubt it is the bulb as it looks new and the image had not diminished at all in recent weeks - we...
hi,
All projectors have self dioganisng function. If there is any malfuction inside the projector it will indicated by the LED blinking. You have to inspect how many time the LED blinks or which LED lights condinuosly. LED meas the power light or the lamp light. Then only anybody can suggest you a better solution.
ok
1helpful
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
The red lights are blinking under lamp and temp.
did you try setting the lamp over the red light on the tv?
13helpful
Both Temp and Lamp lights blink red
All you should need to do is go to the menu on the projector, and find the Filter Timer. Hit the right arrow to select the filter time, and then hold the rest button on the projector until you are prompted to confirm the reset. Hit menu to confirm and it should now reset the filter timer. Now cut the projector off and back on and the lights should stop blinking. I hope this helps.
2answers
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Mitsubishi WD-52725
SEDI-POSSIBLY YOUR SET HAS A LOW 5 VOLT POWER SUPPLY.TEST VIA VOLTMETER ON PLUG J-9 WHICH IS ON LITE ENGINE .YOU WILL NEED TO REMOVE BACK OF SET TO MAKE THE TEST.IF 5 VOLT IS LOW BEST TO CALL A MITSUBUSHI TECH.JOE TV
Top ViewSonic Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
