Just installed a new battery in my eMachine M6811. Left it plugged in overnight to get a full charge. Woke up to a flashing yellow power indicator. Unplugged charger and started up. Battery power indicator says only 52%. How can I get this fully charged? Should I replace the AC charger?
SOURCE: INSTALL XP ON EMACHINES M6811 WITHOUT CD
If you have another pc, network the two and share the cd drive of the other PC
SOURCE: Emachine Turns Off
This is the best way to tell. If your system is shutting down on you by behaving like your shutting it down thru windows then it could be a spyware, virus trojan issue going on. If thats the case then run your virus program and see what it finds and remove it. If your laptop is shutting down on you where everything turns off right away with no lights, kind of like a power outage then go ahead and remove the battery and only use the ac adapter and see if that solves the problem. If it does solve the problem then you know its your battery that is the culprit. If your only using the ac adapter and the machine shuts off on you like a power outage with no lights then you know its a problem with the motherboard. With just the ac adapter plugged in, wiggle the cord near where it plugs into the laptop and if it shuts off on you like a power outage then you know its a loose DC Jack and it needs to be resoldered back into place. Hope all this helps.
SOURCE: My emachines m6811 screen shows a poor quality
Sounds like the pc is set to a low pixel setting, try going to properties and adjust display settings.
ie. Right click on desktop image, click on Properties. WIndow will pop up, click on SETTINGS tab and adjust Screen Resolutions and/or Color Quality. That should make the change. Sometimes programs installed changes those settings. Good Luck!
