Question about Technics SL-1200 Turntable
Tone arm skipping records.
Im not really sure what is the cause of this problem, but my needle keeps skipping records on one of my technics 1210. ive adjusted everything that can be adjusted and even bought new needles and it still happens.I thought it could have been a weight issue, but clearly not as I have tried adding extra weight but I still have the same problem. I think its coming from the arm itself.What do u guys rekn?
    Scholar:
  • 85 Answers
The anti skate adjustment. And if you scratch @ all....move the weight all the way in and take off the little extra one that screws in on the back. Also a great tracking needle is a M44G.
Posted on Apr 28, 2010
6ya staff
SOURCE:
Marantz tt 530 turntable
The needle skipping is caused by (A) a worn stylus. (B) not enough pressure. Which is solved by adjusting the weight on the end of the arm. It can only really be solved by trial and error. You increase the weight slightly, then play the record. You keep doing this till the record stays in the grooves but doesn't make a rumble sound. If it starts to rumble reduce the weight.
Aug 20, 2013 | Audio Players & Recorders
Needle keeps jumping back 4 bars on records
CHECK ANTI SKATING SETTING SHOULD BE SAME AS STYLUS FORCE ABOUT 3.ADJUST TONEARM HEIGHT SO IT IS PARALLEL TO RECORD WHEN PLAYING.HAS THE DECK HAD NEW PHONO CABLE FITTED RECENTLY IF SO THIS WILL BE THE CAUSE GET IT DONE PROPERLY.
May 03, 2010 | Technics SL-1200MK2 Turntable
How do i free up the tononig arm on a technics 1210 deck? It is stiff and wont move across the record.
It should really be replaced but you can try adjusting the screw on the top of the arm
Dec 23, 2009 | Technics SL-1210 Turntable
One of of my technic 1210's keeps picking up dust and the sound quality is poor regardless of the needle. It has ruined 2 needles now and and im not sure the problem is. The weights are not too heavy so it...
Are u sure it's not the needle? What brand needles are you using and I usually recommend people have small fans by turntables to have airflow so dust doesnt become a problem, expecially for DJ's
Nov 25, 2009 | Technics SL-1210 Turntable
Sears Tape deck/Turn table skipping!
Hi the pennies will mess up the stylus. There should be an anti skate setting at the back of the turn table, a round adjustable bit with numbers, increase the anti skate and then use the balance weigth (weight right at the back of the arm that turns to get the weight right. Set the anti skate with the tone arm light, then increase the weight a bit. Hope that helps
Jun 14, 2009 | Technics SL-1210 Turntable
Technics 1210 tone arm Problem
This table should have an "anti-skate" adjustment. This is out of adjustment and putting to much tension on the arm. This adjustment is designed to insure that the needle tracks in the middle of the groove rather than one side. If the arm is out of balance and this os out of adjustment, the symptom you describe will occur. Hope this helps, Dan
Jun 08, 2009 | Technics SL-1210 Turntable
When i backspin the arm is forcing itself off the vinyl
IMO the problem can be solved in 2 ways, either move the counterweight on the back of the arm towards the turning point of the arm ( by just adjusting it 10 - 20 % of an whole spin you can adjust a lot), or buy an other needle which is heavier then this one...
Jan 29, 2009 | Technics SL-1210 Turntable
Adjustments on Technics SL-B2 Automatic Turntable
the pitch is just the speed, adjust to your liking.
"How do I adjust tracking pressure and anti skate?
If you are lucky enough to have these two adjustments here's how: Move tracking force counter weight till needle suspends/hovers above record. then rotate numbers to zero. (this is zero grams pressure on record) then rotate weight AND numbers to recommended tracking pressure for your needle usually 1.5 to 3 grams is average. Then rotate anti skate to be equal. That should get you there. If you still have adjustment related distortion then it may be time for a new needle.
NOTE: Anti skate is adjusting side to side pressure WITHIN GROOVE of record. Tracking pressure is how hard the needle is pushing down inside the groove." from
turntableneedles.com/FAQs_ep_33.html
lots of crackles are caused by crummy records and needles. to some small degree are unavoidable no matter what, but above all the records must be clean.
someday the manual may show up for free here
http://www.vinylengine.com/library/technics/sl-b2.shtml
Dec 02, 2008 | Audio Players & Recorders
1210 problem
Those are just standard phonograph player characteristics in my experience. You'll hear a tap on the deck because there's essentially a live mic ( the needle ) physically coupled with the record on the turntable and the rest of the phonograph player even though they try to dampen the coupling of the turntable as much as possible. The rumbling noise at high gain is because the turntables being driven by a motor via gears or a belt and creates some  vibration, wich is transmitted through the turntable and picked up by the transducer ( needle ), low frequency rumble, just like a recording studio on a busy street may pick up from road vibration/ noise.
Aug 06, 2008 | Technics SL-1210 Turntable
1210 Constantly Skipps
More than likely your tonearm is damaged. There is a small screw towards the rear of the tonearm. If you loosen this it may solve your problem. However, please be careful, because once you adjust this screw, it is very hard to get it right. That screw is known as a 'conical' screw, and has a cone shaped tip. This tip sits on top of 4 very small ball bearings, which are held in place by a very thin piece of sheet metal. If any of these are damaged, you will have to replace the tonearm. If they are not damaged, and your conical screw just became misaligned, then it is possible to salvage your tonearm. However, be very careful when turning this screw. Turn it counterclockwise very slowly, about a hair of a turn... yes, I said a HAIR of a turn. Then put the needle back on the record and observe what happens. If the problem persists, turn it a little bit more. Keep doing it until the problem is solved. You will eventually have to have the tonearm replaced, as this screw will start to loosen over time, once it's been adjusted.
- OPTiC
DJ Pro Audio
www.djproaudio.com
www.1200s.com
www.repairnyc.com
Jul 27, 2008 | Technics SL-1210 Turntable
Technics SL-1200 Turntable Logo
417 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
