SOURCE: Incoming Call not Ringing
Either call line 3 first, or make your phone ring :-)
What might be the easiest is to swap modular plugs in the back room between 2 and 5. That way, you get your old extension back and everything will work as it did.
If you can't do that, then you're going to have to do some system programming to turn on the ringing on your phone. If you have a TA series system, you should be able to do it from either the PC or a phone connected to jack $1. If you have another model, you should have a system manual on how do make programming changes.
Carl
SOURCE: Can not pick up line on incoming calls from one extension only
That's what happens when you plug in the system and don't program it. You need to review ICD groups.
By default, the phone connected to the first extension is the master phone and the only phone that rings.
Carl
SOURCE: Incoming calls ring on intercom rather than appropriate line.
Somehow you might have taken the lines off the extension. I would double check that under line appearance, that extension is set to "appear and ring" for each line.
SOURCE: Executone 64 System: Only certain extensions ring
http://www.executonesystems.com/documents/IDS_UserGuide.doc
Try going to this user guide and see if this helps.
SOURCE: RCA Executive Series 4-line model# 25413RE3-A
I was having the same problem...no caller ID. Then I looked up the phone on the RCA site:
http://www.rca4business.com/products/pc/viewPrd.asp?idcategory=22&idproduct=11
Turns out there is no called ID on this model =(
