Hello :
Check this link for manual : http://www.manualsonline.com/search.html?q=bunn+Coffee+Brewers+&submit.x=50&submit.y=11
good luck .
rate if useful please !
Hello. the problem is the little sprayer that sprays water into the coffee grounds. They get clogged with coffee oil and coffee grounds. Unplug the machine, tip it upside down in the sink so the water doesn't go everywhere and use a straight pin to clean out the little holes of the spray nozzle. That nozzle should unscrew, which would make it easier to clean. When you are looking at the nozzle, unscrew it by turning it counterclockwise. Joe
That is not the problem. It has been cleaned and no clogs. Can see through each little hole.
The sprayer holes are clean. Any other suggestions?
