How do you know it's the pedal. The reason I ask is that I'm having the same problem and took the cover of underneath the pedal to try it manually and had no luck. I think the problem may be elsewhere with one of the other wires. In the past I have had problems with it only working in Hi speed and realized one of the wires had come loos at the connector. I brought it up after spending the winter in the basement and it worked fine the first time around. Then I turned it over to fix a problem with the solder coming loose on the front steering and after that I'm not able to get it to work as there is no power going to the wheels. Intermittently I will get power but not on a consistent basis. I don't think it's a battery charge issue, but a loose contact from when I had it turned upside dow
ENGINE HESITATES WHILE ACCELERATION
LOSS OF ACCELERATION
It
can be fuel pressure issue or it's the problem with accelerator pedal or its
clogged filters causing there.
There
are many other possibilities. I suggest you to go through the list of help
links mentioned below, these will help you to confirm where the actual fault
lies: -------
http://technoanswers.blogspot.in/2012/02/loss-of-acceleration.html
http://howtobyme.blogspot.in/2012/02/headlights-flickering-and-car-hesitates.html
http://repairhelpcenter.blogspot.com/2011/11/how-exactly-vehicles-accelerator-cable.html
http://repairhelpcenter.blogspot.com/2011/11/how-exactly-vehicles-accelerator-pump.html
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-engine-lean-codes.html
http://whatisbyme.blogspot.in/2012/05/2004-toyota-avensis-acceleration-and.html
http://technoanswers.blogspot.in/2012/04/wheel-hop-under-hard-acceleration.html
http://technoanswers.blogspot.in/2012/02/2009-chevy-impala-accelerator-pedal.html
http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-stalls-and-bucks-on.html
http://repairhelpcenter.blogspot.com/2012/01/acceleration-lag-problem.html
These details will help.
Thanks.
